Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 56
  1. #11
    Forum Deity NBC's Avatar
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    when using the annotative features:
    for text styles, you set up the text style to have a paper space height, and a tick in the Annotative box. no other setup or calculations are required.
    for dimensions styles, these should be setup for use as if you would use them in paper space (ie, dimscale = 1), AND a tick in the Annotative box. no other setup or calculations are required.
    then you need to setup your SCALELISTEDIT.
    once you have gotten that far, see the link I posted above.
  2. #12
    Super Member happyunited's Avatar
    AutoCAD 2010
    Jun 2006
    Manchester, England
    588
    i set up a dimstyle on friday but how do i set up a textstyle? there is one already in place but how do i edit it? thanks again
  3. #13
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    enter STYLE at the command line
  4. #14
    AutoCAD 2010
    Jun 2006
    Manchester, England
    588
    SCALELISTEDIT - i think this is what is causing the problem. if i amend this list is it only specific to that drawing or can i apply it to all the drawings at once?
  5. #15
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    Quote Originally Posted by happyunited View Post
    you can amend that list in your template, and it should then apply to all your drawings
  6. #16
    AutoCAD 2010
    Jun 2006
    Manchester, England
    588
    but will i have to do that to all 10 templates? that will take ages!
    sorry for asking so much!!
  7. #17
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    try it and see - it's a good way of learning
  8. #18
    AutoCAD 2010
    Jun 2006
    Manchester, England
    588
    i have attached a bit of the thing i am trying to work on.
    as i said to get a scale of 1:10 in my VP i enter 100 in the vp scale box but in my text properties box its saying the paper space and model space height is wrong!!
    1:10 text height should be 0.025 so that X 100 = 2.5!!!!!
    thansk again
  9. #19
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    one other variable you need to be aware of is CANNOSCALE.
    this sets the current scale for annotations.
    this should usually match the scale of the viewport you want the annotations to be visible in.
    I have updated your drawing accordingly, and setup your dimension & text style to be annotative.
  10. #20
    AutoCAD 2010
    Jun 2006
    Manchester, England
    588
    thank you.
    what did you do? was it the annotation scale i had wrong?
  1. Annotation Scaling 103
    By AutoCAD Insider in forum AutoCAD RSS Feeds
    Last Post: 10th Jun 2009, 02:26 pm
  2. Annotation
    By Beale in forum AutoCAD General
    Last Post: 20th Jul 2007, 02:39 pm
  3. Annotation Scaling 106
    Last Post: 10th May 2007, 01:32 am
  4. Annotation Scaling 104
    Last Post: 18th Apr 2007, 05:40 pm
  5. Annotation Scaling 102
    Last Post: 4th Apr 2007, 06:20 pm
