Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 50 of 50
Thread: defpoints
  1. #41
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,108
    Quote Originally Posted by NBC View Post
    It wouldn't be the first time in my career that I have been labelled as a 'trouble causer'.
    I will try this again later, and also at work tomorrow.
    I don't see why anything would change, nor how you have gotten defpoints to purge in the way you guys have.
    NBC,
    You are correct in saying AutoCAD says this can't be done, but yet it can be done. As stated earlier, Defpoints shows as an "Item that cannot be Purged" yet it purges.
    I wonder what other lies Autodesk has perpetrated.
  2. #42
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    Hey, Blue, sounds like you definitely need that Down Under holiday. Get away from that cold weather. No wuckers, mate, I will look after you.
  3. #43
    Forum Deity NBC's Avatar
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    ok, so this works when i hit purge all.
    from that then, is reasonable to assume that is the same as -purge a * n ?
  4. #44
    Map 3D 2009
    Jun 2006
    4,181
    You really want me to go back and try that?
  5. #45
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,108
    To make things easy just make a button Macro.
    ^C^C_purge a * n
  6. #46
    Map 3D 2009
    Jun 2006
    4,181
    well, after much effort, and much command line prompts, I ended up with 0 and defpoints. so as far as I am concerned, command line purge is crap.
  7. #47
    Full Member
    Land Desktop 2008
    Oct 2007
    salt lake city, utah
    88
    Default deleting defpoints
    I agree with tiger redhead why would you want to delete it? It has been an integral part of autocad for a long time. The nodes on all dimensions used for gripping are on the layer defpoints. If you do a measure command or divide command those points are created on defpoints (you can see those when you change your DDPSTYLE). this is a convienent way to see nodes in various parts of the drawing but they don't plot . I use defpoints all the time for my viewport so you can see it but it doesn't plot hence tuning on and off a vp layer. With the advent of adding a no plot option in layer manager defpoints has been not as important for a no plot layer. Another note about defpoints it is linked to layer 0, if layer 0 is frozen you can't pick anything on the DEFPOINTS layer
  8. #48
    Super Member riga's Avatar
    AutoCAD 2007
    May 2007
    Switzerland
    723
    riga, could you redo img1, but expand the layers to be purged?
    Sure, sorry. I was on my way to home.
    Be sure that your settings are the same as mine.
    I know here nobody care about deleting or not this layer.... it's more on the way autocad sometimes work funny
    HAVE A NICE DAY
  9. #49
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,108
    Quote Originally Posted by beammeup View Post
    Like I said, even if you purge it, it will come back when needed.
    You need to be careful putting objects on Layer Defpoints, AutoCAD has problems when you do that, it has been discussed on here previously. Just create a layer and make it a "No Plot" layer.
  10. #50
    AutoCAD 2007
    May 2007
    Switzerland
    723
    I have to agree that "Defpoints" is a strange layer. It will be created when needed, and it can be deleted when it should be impossible to delete him.
    I've noticed now that in the drawing posted by NBC "Defpoints" was frozen a did not appear on the list of the layers that purge will delete.... but after purge it is disappeared.
    I've even tried to lock it .... same result, after _purge (purge nested object checked) it will be erased
    HAVE A NICE DAY
  1. Defpoints - "Can't Touch This"
    By O Snap! in forum AutoCAD Drawing Management & Output
    Last Post: 8th May 2007, 09:05 am
  2. Defpoints?
    By gw4100 in forum AutoCAD Beginners' Area
    Last Post: 31st Aug 2006, 02:42 pm
  3. Defpoints and Zero
    By chance in forum AutoCAD Drawing Management & Output
    Last Post: 16th Aug 2006, 06:48 pm
  4. Can I create several defpoints layers?
    By afry in forum AutoCAD Drawing Management & Output
    Last Post: 9th Dec 2005, 05:11 am
  5. Points on Defpoints Layer
    By WannaBeCader in forum AutoCAD Drawing Management & Output
    Last Post: 30th Nov 2005, 03:48 pm
