what program produced the original?
I think there's a command that does something similar to purge, except that it erases duplicates as well
when you open the drawing do you get a proxy warning?
I have a survey with existing text on it, which I need to edit. When I pick the text, it increases in size about 10 times, and duplicates itself just as many. Needless to say, I still haven't corrected it as of yet.![]()
Find your newbest friend
at
Rain Rescue
If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
I believe the survey is Map 3d. When I open it I don't get any warning boxes.
Can you post the DWG?
Have you considered that the text is annotative? I would suggest you get onto NBC fast. He will sort it out for you very quickly (I hope).
