Results 1 to 2 of 2
    Junior Member
    AutoCAD 2004
    Oct 2007
    13
    Default Geometry in Text
    OK friends, help me out in this.
    I am a newbie at autocad. My very first day, and facing a problem.
    I have some 1500 points (numbered from 1-1500) with their X, Y and Z positions in property tab. The data is from total station device.
    What I want is that Z Position of all points appears along with Text number (i.e. numbers from 1-1500). Is there any command to do this.
    Otherwise I have to manually put in all the values
    I am using AutoCAD 2004.
    Junior Member
    AutoCAD 2004
    Oct 2007
    13
    pls delete this thread. posted in wrong forum by mistake
  1. EXPLODING TEXT TO GEOMETRY
    By dangermouse in forum AutoCAD Beginners' Area
    Last Post: 7th May 2007, 08:30 pm
  2. Rendering Geometry
    By the_duke in forum AutoCAD 3D Modelling & Rendering
    Last Post: 11th Nov 2006, 07:29 am
  3. project geometry
    By ploeg8393 in forum AutoCAD General
    Last Post: 7th Sep 2006, 09:04 pm
  4. Geometry Problem
    By Rockero in forum AutoCAD Beginners' Area
    Last Post: 13th Jul 2006, 03:33 pm
  5. Scaling of Geometry> what do you do?
    By MGV in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Jul 2005, 07:32 pm
