Results 1 to 7 of 7
    Forum Newbie
    AutoCAD 2007
    Oct 2007
    1
    Default how to delete a block from the Insert block list
    Hello,
    I am using Autocad 2007 I made several blocks with att. And I use this drawing and copy it to the samples/design center folder so that I can see the blocks that I created on the Design center window for use on different other drawings.
    My problem is that if I make a cange on the ORIGINAL block drawing how can I update the inserted blocks on the other drawings? I try to delete the block from the local drawing insert block list (is this possible?) to paste the block again with the new changes, but somehow even when I grab the new modified block to inserted again when I do it, it takes the shape of the old version!!
    Help Please!!
    Super Member Raggi_Thor's Avatar
    AutoCAD 2008
    Aug 2007
    Trondheim, NORWAY
    718
    You can only delete a block from the list if it's not used in the current drawing, that means no copies or references to that block.
    Then you can PURGE the block definition.
    If the block is used (referenced) in the current drawing, you have to update the local definition of that block. The traditional way to do this is to have a dwg file (made with the command WBLOCK) and then use the command INSERT and Browse. You will get a notification, "Update? Yes/No".
    I am not sure if designCenter can be used to update existing block definitions. Try to double click instead of drag and drop. I'm afraid you'll get a small note like "duplicate definition ignored".
    Mvh, Kvedja, Kind Regards,
    Ragnar Thor Mikkelsen
    http://www.DESIGNDATA.no/English.htm
    Full Member 19cruthik68's Avatar
    Electro/Mech
    19cruthik68's Discipline Details
    Draftsman
    Electro/Mech
    AutoCAD 2012
    Sep 2011
    Doha, Qatar
    82
    How can I delete a block from the list if it's not used in the current drawing? So that the file size would be less.
    and so I did.
    Senior Member
    danellis's Computer Details
    Windows 7
    Dell Precision T1650
    Architecture 2014
    Dec 2010
    321
    Use this PURGE command.
    dJE
  5. #5
    Electro/Mech
    Draftsman
    Electro/Mech
    AutoCAD 2012
    Sep 2011
    Doha, Qatar
    82
    ty it helps. dont know how to use this purge thats why.
    and so I did.
  6. #6
    Luminous Being dbroada's Avatar
    dbroada's Computer Details
    Windows 7 Professional
    Dell
    Intel Xeon E5-1603@2,80GHz
    4GB
    NVIDA Quadro K600
    DELL 23" & SAMSUNG 21"
    not applicable
    Nov 2005
    Kenley, Surrey, UK
    5,644
    PURGE is the way to clear out any unused information like blocks and layers. Press F1 for fuller information.
    "That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
    "Everything in drafting is logical. Except what isn’t." - Gavin Guile. (from the Lightbringer series of books by Brent Weeks)
    Dave
  7. #7
    AutoCAD 2013
    Nov 2011
    6,051
    Enter PURGE at the commandline, and the PURGE DIALOG box will open as in the image.
    If you have the settings shown like in the image, then wherever you see a + sign on the list, there are some items which fall into that category which are unused and could be purged by pressing PURGE ALL.
    Should you want to you can click on one of the categories with a + and you will be shown purgeable items of that sort.
    I usually use the PURGE ALL option, and check the Unnamed Objects box too which may purge any pesky zero length geometry and empty objects.
    After you PURGE ALL, close the window,
    It is also a good idea to AUDIT a drawing before you do a final SAVE on it.
  1. Insert A Block
    By raj banerjee in forum AutoCAD General
    Last Post: 10th Oct 2007, 12:21 pm
  2. A list of Cad Block sites
    By Diogenes in forum Catch All
    Last Post: 30th Jun 2007, 09:08 pm
  3. How insert block without dialog box ?
    By rickobr in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Oct 2006, 06:15 pm
  4. how can I delete a block with vba, help me!
    By jeans in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Jul 2005, 07:16 pm
  5. Very odd... Can't insert a block into new dwg
    By blast9 in forum AutoCAD Drawing Management & Output
    Last Post: 15th Feb 2005, 08:48 pm
