dswinty Posted October 23, 2007 Share Posted October 23, 2007 Double click editing does not work even though it is selected in options. Also, when I try to rotate a view in mvsetup it rolls 180 degrees instead of the 90 I entered. Use 2007. Do I need to reload? Quote Link to comment Share on other sites More sharing options...
Cad64 Posted October 24, 2007 Share Posted October 24, 2007 Double click editing does not work even though it is selected in options. This is usually a result of the Pickfirst variable being set to 0. Type PICKFIRST at the command line and change the setting to 1. Not sure about your second problem? Quote Link to comment Share on other sites More sharing options...
tzframpton Posted October 24, 2007 Share Posted October 24, 2007 Double click editing does not work even though it is selected in options. Also, when I try to rotate a view in mvsetup it rolls 180 degrees instead of the 90 I entered. Use 2007. Do I need to reload? while in MVSETUP are you using the mouse, or are you typing the rotation in the Command Line? Quote Link to comment Share on other sites More sharing options...
dswinty Posted October 24, 2007 Author Share Posted October 24, 2007 I figured out the pickfirst thing, but not the rotation problem. I am typing in the rotation angle. The drawing is horizontal and when I type in 90 degrees, it goes 180. Quote Link to comment Share on other sites More sharing options...
GE13579 Posted October 24, 2007 Share Posted October 24, 2007 Is it only on the one drawing or is it on all drawings? If just the one could you post it at all? Quote Link to comment Share on other sites More sharing options...
dswinty Posted October 24, 2007 Author Share Posted October 24, 2007 It appears that after rebooting 50 times the problem is gone. Not sure what happened. I appreciate the help and if it happens again I will repost and include the drawing. Thanks again! Quote Link to comment Share on other sites More sharing options...
qutub Posted June 11, 2011 Share Posted June 11, 2011 thanks alotttttttttttttttttttttttttttttttttttttttttttttt cad54 i love to do that and my autocad is works fine now. just because to reply you i make my id in this forum. thank u thank u thank u thank u somuchhhhhhhhhhhhhhhhhhhhhh:D This is usually a result of the Pickfirst variable being set to 0. Type PICKFIRST at the command line and change the setting to 1. Not sure about your second problem? Quote Link to comment Share on other sites More sharing options...
qutub Posted June 11, 2011 Share Posted June 11, 2011 my f1 button is also not working what to do any suggection or help dude cad 64 Quote Link to comment Share on other sites More sharing options...
Cad64 Posted June 11, 2011 Share Posted June 11, 2011 What do you mean your F1 button is not working? Does it work in other programs or is the problem just in Autocad? What happens when you press F1? Anything? Any error message? What happens when you go to the "Help" menu? Can you access the Help files from there? What about if you type HELP at the command line? If you can't access the Help files from any of the methods I mentioned then you probably need to run a Repair from your installation disk to fix the problem. Quote Link to comment Share on other sites More sharing options...
qball Posted June 13, 2011 Share Posted June 13, 2011 have a look at this article that talks about changing the F1 key to Cancel. If it just started happening, then this modification probably has not been done. Then I don't know what the cause would be. http://lynn.blogs.com/lynn_allens_blog/2005/10/the_best_autoca_1.html Quote Link to comment Share on other sites More sharing options...
javid Posted June 11, 2013 Share Posted June 11, 2013 Thank you for your useful information about this problem:):) Love you all Good Luck Quote Link to comment Share on other sites More sharing options...
