autocad 2007
Last edited by nathan008; 24th Oct 2007 at 06:30 am. Reason: forgot to include version
autocad 2007
Nathan
I can not answer your question -I do mechanical works. But please start a new thread when you post a question.
Welcome in the forum!
It's nice to be nice, but sometimes is nicer to be evil!.
Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
I'm not quite sure what you're after. The command ROTATE lets you rotate your drawing quite easily. I would draw lines (RAY or XLINES) from the floorplan to the elevations so that they match.
I hope that is what you're after - otherwise, please come back with more info![]()
Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
at the moment in one's personal UCS.
Go to PLAN view instead. - Dadgad
You can also use an old drafting board technique called projection. A good explanation for it can be found in the book Engineering Drawing by Thomas E. French. The trouble with starting one's drawing career in CAD is one does not get an appreciation for the methods that came before. In many cases the lessons of old can still be applied today.
