Hello all I’m looking for some help. I’m new to cadtutor so I hope I’m putting this in the right spot. Any ways here goes.
I’m trying to get it so when I insert a block with 1 text input A-Cad will set a NewView around that block placement and name it the same as the text entered for the block text input.
The reason behind this is I’m marking problems on the drawings 0001, 0002, 0003, 0004 000…. It works well for finding your block that you marked the problem with. But its tier sum typing in the 000X once for the block input and then again for the Newview Name.
I would also like it if the command would repeat until I chose a new command or pressed Esc
This is what I’m using right now
^c^c_Insert;\\_Newview;\;
A-Cad 2008
Any help would be great
Thanks
Brian_sme
Is this even possible?
