Results 1 to 7 of 7
    Full Member
    Mechanical 2008
    Jan 2007
    51
    Default changing dimension color
    I can't figure out how to just change the color of just one single dimension in my drawing. I have 3 main dimensions, two of them I want to be red, and one I want to be white. I tried "dimstyle", and I went to modify > text, but that changes the colors of all my dimensions in the drawing, say I want to just change the color of just one single dimension. Does anyone know how to do that?
    Trying to figure out how to use AutoCAD mechanical 2008 after upgrading from CADkey '97.
    Super Member GE13579's Avatar
    GE13579's Computer Details
    Windows XP
    Fujitso Siemens
    3.4Ghz
    Samsung 19" TFT
    Mechanical 2009
    Feb 2007
    North East England
    1,454
    Get the properties window open....?
    Full Member
    Mechanical 2008
    Jan 2007
    51
    Yes I do, but it doesn't do anything when I click on the dimension and then change the color. (sorry I sound like such an idiot here, but I'm sure I'm probably overcomplicating things. To change the entity color in CADkey '97, it took like 5 steps...)
    Windows XP
    Fujitso Siemens
    3.4Ghz
    Samsung 19" TFT
    Mechanical 2009
    Feb 2007
    North East England
    1,454
    In properties you should have a text drop down menu where you can change the text colour, and a lines and arrows drop down, where you can change the dimension lines and arrows' colours.
  5. #5
    Full Member
    Mechanical 2008
    Jan 2007
    51
    Lol, I see that now. The only thing that was visible before was the "general" section in the properties menu. Just as I thought that was ridiculously simple.... I did try using help at first, but it was getting to exactly what I was trying to do.
    In CADkey, I had to first exit out of everthing, then click format>entity>change>color>"select color">single>"select entity">OK. It took me forever to figure that out. The simplicity of this program blows my mind, but I do appreciate the help very much. I'm catching on.
  6. #6
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,092
    You must first select the dimension then right-click properties.
    If you want to change the color of the entire dimension, under the General heading, just select Color and change it there or select Bylayer under Color and select Layer and place it on a layer of the color you want.
    To change colors of individual components of the dimension, you can do that under the individual headings, Lines & Arrows: "Dim Line color" & "Ext Line color" and under Text: "Text color"
  7. #7
    Full Member
    Mechanical 2008
    Jan 2007
    51
    Quote Originally Posted by SLW210 View Post
    Cool, thanks a lot for the reply bud. I appreciate it.
  1. Changing Screen Color
    By Paul Sweet in forum AutoCAD General
    Last Post: 4th Jul 2008, 10:07 am
  2. Changing Layer Color with VB
    By sailor in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Aug 2007, 12:14 pm
  3. Changing the color of an object?
    By RMS in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th May 2007, 12:51 am
  4. Changing color of history objects
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 14th Feb 2007, 01:23 am
  5. changing color in color control (layer )
    By ionica in forum AutoCAD Drawing Management & Output
    Last Post: 10th Oct 2005, 07:45 pm
