This lsp routine works great, does anyone know how to remove the spaces in the bearing? Example: N 88°53'14" W to N88°53'14"W.
Thanks,
Gregg
Thanks to Dinosaur for solving my LBL2.lsp problem. Surveyors using this powerful routine and Ver 2006 should read his solution.![]()
Thanks,
Gregg
You'd need a simple sup to remove the spaces before the string is place into a piece of text. However, I'm confused; if you have Civil 3D, why not just use C3D bearing labels?
DropBox | finding the light...
Seann: ...it went crazy ex-girlfriend on me...
eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
I'm probably not using C3D to its fullest potential, however from what I've seen if I wanted to label the overall R.O.W. line with a bearing and distance, than label each lot line coming off that R.O.W line with just a distance (bearing will already by supplied by the R.O.W. label...reduces redundant labels) I would have to have a separate line for each lot and another line for the R.O.W., creates a lot of redundant line work and doesn't look nice and clean.
C3D appears to be more of an engineering tool than a surveying tool, but if there is a better way I would be willing to listen.
Thanks
Gregg
