Use the Menuload command
Hello
how to convert mnu file to cui file manualy
because original menu file had modified therefor i had to modify cui file to reload it to reflect modification
i know that autocad covert menu file to cui file automaticaly for first time
thanks
...or the ._MENU command.
i try to use the menu load but always gives error
that mean you can't load menu but you can load cui ,therfore cui file can't be updated in this way, is my speach correct
thanks
Both the MENU and MENULOAD commands will accept a MNU or MNS file and convert it to a CUI file.
A picture is worth...
i tried to load menu but alaways gives error reading file
but mns file okay
so in this case any modification must apply on mns file so we can load unload
my toolbar
thanks
It *is* picky on menu file syntax.
If your MNU or MNS doesn't follow documented syntax - you may have problems, either during or after the conversion.
