Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
    Senior Member
    AutoCAD 2014
    Sep 2007
    105
    Question Labelling Points/nodes
    If I Insert A Point In Autocad, It Has An X,y,z Coordinate.
    Is It Possible To Label This Point So It Can Be Exported With The X,y,z And Label Information Into Another Program Ie Excel.
    Thanks
    Full Member kimkat_tkl's Avatar
    AutoCAD 2008
    Nov 2006
    Brisbane, Queensland
    37
    If you use the LIST command you can copy the coordinates from the Text Window and paste into excel
    Senior Member
    AutoCAD 2014
    Sep 2007
    105
    The Problem Is I Need To Label A Point.
    I Can Get The Point Coordinates Into Excel Using A Lisp Routine I Have No Problem But I Need Each Set Of Coordinates Labeling. Are There Any Lisp Routines To Label A Point Or A Set Of Points.
    If I Select An End Point Of A Line And Insert A Point I Would Like An Option To Label That Point. Does That Make Sense?
    Thanks
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    If instead of a point you use a Block with an attribute, and for each point (block) insert include a label for the attribute value, you can export the information using "attext" or similar.
  5. #5
    Senior Member
    AutoCAD 2014
    Sep 2007
    105
    Default labelling points
    obviously use the base point of the block as my point of coordinate
  6. #6
    Senior Member
    AutoCAD 2014
    Sep 2007
    105
    sound like that suggestion will work but struggling to get attext to work.
    carl b can you shed some light on the template file option on attext command please
  7. #7
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
  8. #8
    Senior Member
    AutoCAD 2014
    Sep 2007
    105
    Question Points
    Is It Possible Though To Insert A Block That Automatically Inserts The Coordinates Of That Point Into The Block Only For Me To Lable That Block.
    Then I Want To Use Eattext Command To Export This Info.
    Thanks
  9. #9
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    You should be able to extract the block's insert point coordinates without them being attributes.
    See http://www.brianmorse.com/ASCII%20Po...m%20blocks.php for (I think) a similar approach.
    You could make a custom block with various attributes, insert it using a custom routine (lisp or vba) and have x & y values automatically entered as attributes.
  10. #10
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    What sort of label are you trying to put on each point? will all the labels be the same? Are the points on different layers relating to what they represent? Is this a survey?
  1. Unwanted Nodes
    By trin_rob in forum AutoCAD Drawing Management & Output
    Last Post: 25th Apr 2012, 03:47 am
  2. how do I add nodes to a polyline?
    By Anna_here in forum AutoCAD General
    Last Post: 30th Oct 2008, 02:17 am
  3. Nodes
    By Burnsie in forum AutoCAD Beginners' Area
    Last Post: 17th Sep 2007, 05:59 am
  4. help with nodes!
    By CustomLaserWorks in forum AutoCAD General
    Last Post: 6th Jun 2007, 09:06 pm
  5. Grips and Nodes
    By DJM001 in forum AutoCAD Drawing Management & Output
    Last Post: 20th Jan 2005, 01:18 am
