Why dont you try sothing like this.
or you can make a lisp that allows you to insert a block and then using macros tell the block to do a task.Code:(defun c:spinblk (/ doc ss ll ur midpt) (vl-load-com) (if (and (ssget '((0 . "INSERT"))) (setq doc (vla-get-activedocument (vlax-get-acad-object) ) ) (setq ss (vla-get-activeselectionset doc)) ) (progn (vlax-for ent ss (vla-getboundingbox ent 'll 'ur) (setq ll (vlax-safearray->list ll) ur (vlax-safearray->list ur) midpt (mapcar '/ (mapcar '+ ll ur ) '(2.0 2.0 2.0) ) ) (vlax-invoke ent 'rotate midpt pi) ) ) ) (princ) )
