No!
But there are a lot of members who will see me post here. So you will get the answer you need shortly.![]()
Okay, I'm a deviate.![]()
For some reason I cannot osnap to my dimensions anywhere (endpoint, node, etc...) Anyone know if this is an option somewhere or what is the fix for this?
AutoCAD 2008 Mechanical
Let me know
Thanks
Vic
No!
What exactly are you trying to do?
Could you post a DWG?
All I want to do is move a dimension... and i want to grab the end point of the dim line... and there is no highlighted osnap
Is it working on other than dimensions?
Is this only in a single drawing? If so try an audit or recover. Did you create the drawing?
It happend on all your drawing? I can't see at the moment an option that will deactivate osnap to dimensions and not to other objects
HAVE A NICE DAY
Do you mean osnaps or grips?
If you mean grips you have to be sure they are enabled
HAVE A NICE DAY
It is working on other objects (ie viewports, titleblock objects)... Its only the Dimensions...
