Hiya people - FAQ crew needs help again - what a surprise right?
This is what we got right now:
now, what I was thinking was, is there any chance of making this FAQ more non-version-specific? More importantly - does this solution work for all versions?Templates won’t open [beta]
Templates created using 2007 version of AutoCad can only be saved as a 2007 .dwt file. They cannot be saved as a 2004 version .dwt file.
To create a 2004 version template file in 2007, the file needs to be saved as a 2004 drawing. Then close the drawing and manually change the file extension from .dwg to .dwt.
uhm...kinda like this:
am I right? *crosses fingers*Templates won’t open [beta]
Templates created using a specific version of AutoCad (for example 2007) can only be saved as that versions .dwt file (i.e 2007 dwt.file) . They cannot be saved as a lower version .dwt file, which means the template can't be opened in a lower version of AutoCad.
To create a lower version template file in a higher version AutoCad, the file needs to be saved as a lower version .dwg-file first. Then close the drawing and manually change the file extension from .dwg to .dwt.
Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
at the moment in one's personal UCS.
Go to PLAN view instead. - Dadgad
ok, so this is how it turned out - looking good?
Bluey - we need a stamp of approval from you if you don't mind?Template won't open [beta]
Templates (.dwt files) can only be saved as the version in which they were created. It is not possible to save them to a lower version, as can be done with .dwg files.
To create a lower version template file from a higher version of AutoCad, the file needs to first be saved as a .dwg in the appropriate version. Then close the drawing and manually change the file extension from .dwg to .dwt.(http://www.cadtutor.net/faq/questions/35/)
