I want to create a company toolbar external rather than doing so via CUI. i have about 10 options by say 3 toolbars.
Can you export out somehow an existing tool bar to a txt file I expect it would have a description, icon name, commands etc as per the cui. This I would edit with my BMP's, commands etc then re-import back in. Possibly attached to our company menu's
When 2009 is released I could load menu and toolbars etc.
You could create the old (pre-2006) .MNU file and then when you load it (using MENULOAD) into 2006 or later, it will be converted to a CUI file.
At that point, you can either maintain the CUI file using the CUI command, or you can continue to update the MNU file and reload it each time.
