Results 1 to 3 of 3
    Senior Member
    not specified
    Jan 2006
    211
    Default GROUP operation not working properly
    I'm working with a trial version of AutoCAD 2008, and the GROUP operation doesn't do what it used to do in 2006. I used to be able to take a whole bunch of seperate objects and treat them all as one object by performing the group operation on them. Then, when I move them, they move as one piece, when I rotate them, they rotate as one piece, when I scale them, they scale as one piece, etc. But with 2008, the only thing grouping seems to do is make sure they all highlight together. As for moving, rotating, scaling, etc. the only object that responds to these operations is exactly the one I click on. The others don't change accordingly.
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Try setting Pickstyle=1 (or 3) or Ctrl+H
    Senior Member
    not specified
    Jan 2006
    211
    Super! Pickstyle=1 worked.
  1. Help in use of shelling operation
    By bobray in forum Autodesk Inventor
    Last Post: 1st Sep 2006, 05:59 pm
  2. group command/extend trimm command not working
    By BITDRAUGHTY in forum AutoCAD Beginners' Area
    Last Post: 22nd Mar 2006, 06:01 pm
  3. Modelling Operation Error
    By dreamer in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Apr 2005, 09:26 am
  4. Modeling Operation Error:
    By J-LYLE in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Feb 2005, 09:31 pm
  5. Bryce smoothing operation not quite doing it...
    By billdapart in forum AutoCAD 3D Modelling & Rendering
    Last Post: 21st Dec 2004, 02:42 am
