Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
    Senior Member yrnomad's Avatar
    yrnomad's Computer Details
    Windows 10 - 64 bit
    HP Z220
    Intel core I7 3.4GHz
    16 GB
    nVidia GeForce 9600 GT w/dual monitor output
    1 tb SATA
    (2) 22" Acer LCD
    Electrical
    yrnomad's Discipline Details
    Drafting/Design Electrical contractor's shop
    Electrical
    AutoCAD 2017
    Aug 2007
    Vancouver, WA - USA
    151
    Default How can I globally change attribute color
    Howdy folks
    I've got a project with an architect who doesn't use color by layer on entities and attributes. I've got a routine to change all entities and entities within blocks to color bylayer, but this doesn't help with the existing blocks with attributes in them.
    Can anyone supply code or tell me how to quickly change the attributes with a window or by block to be color bylayer?
    Many thanks!
    Super Member GE13579's Avatar
    GE13579's Computer Details
    Windows XP
    Fujitso Siemens
    3.4Ghz
    Samsung 19" TFT
    Mechanical 2009
    Feb 2007
    North East England
    1,454
    Could you use QSELECT to select what you're after and then change everything in the properties window to bylayer?
    Windows 10 - 64 bit
    HP Z220
    16 GB
    1 tb SATA
    (2) 22" Acer LCD
    Electrical
    Electrical
    AutoCAD 2017
    Aug 2007
    Vancouver, WA - USA
    151
    Quote Originally Posted by GE13579 View Post
    When I use qselect my options seem to only relate to the properties of the block or the value of the attribute.
    Am I not seeing the option you are thinking of?
    Windows XP
    Fujitso Siemens
    3.4Ghz
    Samsung 19" TFT
    Mechanical 2009
    Feb 2007
    North East England
    1,454
    I think I might have missed a part of your post, sorry I'm not all that good with all the terminology yet ...
    How about BEDIT, REFEDIT or ATTEDIT, then select the block and then try properties... I might need some help here myself!
    An alternative to REFEDIT in mechanical (not sure if it's the same across the board), is to double click the block. Failing that I'm not sure I'll be of any more use sorry.
  5. #5
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Bedit, change the color of the attributes, Save block definition, Close block editor. Then Attsync the block.
    You can only Bedit and Attsync one block at a time, so if there are a lot of different blocks it could be time consuming.
  6. #6
    Senior Member Bogbadbob658's Avatar
    Bogbadbob658's Computer Details
    Windows 7
    Asus P8P67 LE
    Intel 2nd Generation Core™ i5-2500
    8GB 1333MHz Dual Channel DDR3 SDRAM
    512MB Nvidia GeForce Quadro FX 580
    1TB Samsung F3 SATA 7200rpm 32MB Cache
    24" Iiyama LCD Monitor - Full HD 1920x1080
    Architecture 2013
    Aug 2007
    Gloucester UK
    327
    Try 'battman' this will allow you to global change the properties to the attribute without changing the values however it will change all of the properties to match so if properties of an attribute has been individualy altered it will be overwritten.
  7. #7
    Windows 10 - 64 bit
    HP Z220
    16 GB
    1 tb SATA
    (2) 22" Acer LCD
    Electrical
    Electrical
    AutoCAD 2017
    Aug 2007
    Vancouver, WA - USA
    151
    The attsync and battman commands seemed to work initially, but then I found text that seemed to have mirrored. Any idea why?
    For example, one of my base plans is grid lines/bubbles for the building. About a third of the 90 bubble's have attributes that are set to yellow for the color while the bylayer color should be 9. This is of course is just one of the blocks that is in this drawing which is one base plan out of close to a hundred.
    I used to work for a company that had a routine (on AutoCAD 2006) that would go through and change all entities to color bylayer, including the attributes then regen. I'm wishing for something similar.
  8. #8
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    Did you try Modify>Change to ByLayer or _SETBYLAYER on the command line?
  9. #9
    Windows 10 - 64 bit
    HP Z220
    16 GB
    1 tb SATA
    (2) 22" Acer LCD
    Electrical
    Electrical
    AutoCAD 2017
    Aug 2007
    Vancouver, WA - USA
    151
    I didn't find the Modify>Change to ByLayer option, and I get the response I get from typing in _setbylayer is
    Command: _setbylayer
    Unknown command "SETBYLAYER". Press F1 for help.
  10. #10
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    Must be new to 2008. I thought 2007 might have it, sorry.
    Maybe you need an upgrade.
    You may be able to find a LISP to do it. I will search around and see what I can find.
  1. When I change the color the dimensions change!
    By Mark Costantino in forum AutoCAD Drawing Management & Output
    Last Post: 12th Oct 2009, 05:55 pm
  2. Attribute edit-Rotate/Move Globally
    By ORgrown in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Jun 2009, 08:01 pm
  3. Change Object Color
    By fade2blackened in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Jan 2009, 02:09 pm
  4. change color of layers
    By Tiger in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Nov 2007, 06:26 pm
  5. can't change color of objects
    By moose321 in forum AutoCAD Drawing Management & Output
    Last Post: 24th Oct 2007, 04:31 am
