Page 3 of 3 FirstFirst 1 2 3
Results 21 to 26 of 26
  1. #21
    Forum Newbie
    AutoCAD LT 2009
    Jan 2009
    5
    Embarrassed
    Where abouts is the pen table?
    Is the area you mean the one I have attached?
    Thanks
    Andy
    [IMG]file:///C:/DOCUME%7E1/ANDREA%7E2.NEW/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]
  2. #22
    Super Member
    wannabe's Computer Details
    XP
    AutoCAD 2007
    Oct 2008
    Birmingham, UK
    772
    Edit your plot style tables.
  3. #23
    Senior Member Bogbadbob658's Avatar
    Bogbadbob658's Computer Details
    Windows 7
    Asus P8P67 LE
    Intel 2nd Generation Coreā„¢ i5-2500
    8GB 1333MHz Dual Channel DDR3 SDRAM
    512MB Nvidia GeForce Quadro FX 580
    1TB Samsung F3 SATA 7200rpm 32MB Cache
    24" Iiyama LCD Monitor - Full HD 1920x1080
    Architecture 2013
    Aug 2007
    Gloucester UK
    325
    Are you using CTB or PST plotting? If you are not sure go as if to plot and check the file name in the top right hand corner. It will end in either ctb or pst. If you can't see the file click the > at the bottom right. If you are using a ctb file then click the button to the right of the file name. You can then edit the file. I would suggest you save it with a new name so as not to effect any other drawings. Sorry if I'm teaching you to suck eggs but I'm not sure of your level of ability.
  4. #24
    Forum Newbie
    AutoCAD LT 2009
    Jan 2009
    5
    Smile
    Quote Originally Posted by Bogbadbob658 View Post
    That worked prefectly. Thank you all very much for your help.
    Andy
  5. #25
    Forum Newbie
    gil9166's Computer Details
    XP
    HP
    1 gb
    HP
    AutoCAD 2008
    Jul 2009
    Canada
    7
    Default color by layer on entities and attributes
    use "Super Purge" command and everything is by layer
    Quote Originally Posted by yrnomad View Post
    Howdy folks
    I've got a project with an architect who doesn't use color by layer on entities and attributes. I've got a routine to change all entities and entities within blocks to color bylayer, but this doesn't help with the existing blocks with attributes in them.
    Can anyone supply code or tell me how to quickly change the attributes with a window or by block to be color bylayer?
    Many thanks!
  6. #26
    Senior Member yrnomad's Avatar
    yrnomad's Computer Details
    Windows 10 - 64 bit
    HP Z220
    Intel core I7 3.4GHz
    16 GB
    nVidia GeForce 9600 GT w/dual monitor output
    1 tb SATA
    (2) 22" Acer LCD
    Electrical
    yrnomad's Discipline Details
    Drafting/Design Electrical contractor's shop
    Electrical
    AutoCAD 2017
    Aug 2007
    Vancouver, WA - USA
    149
    That command wasn't recognized. How do you type it (i.e. superpurge; -superpurge...) Is it a custom lisp you have picked up somewhere else?
  1. When I change the color the dimensions change!
    By Mark Costantino in forum AutoCAD Drawing Management & Output
    Last Post: 12th Oct 2009, 05:55 pm
  2. Attribute edit-Rotate/Move Globally
    By ORgrown in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Jun 2009, 08:01 pm
  3. Change Object Color
    By fade2blackened in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Jan 2009, 02:09 pm
  4. change color of layers
    By Tiger in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Nov 2007, 06:26 pm
  5. can't change color of objects
    By moose321 in forum AutoCAD Drawing Management & Output
    Last Post: 24th Oct 2007, 04:31 am
