Results 1 to 6 of 6
    Full Member
    AutoCAD 2008
    Nov 2007
    46
    Default Toolbar icon size (change)
    Hi. Is there a system variable to change Autocad 2008 icon size in pixels? Defolt is 16x16 and we can enable large icons (32x32).
    But is there a way to change icons to for example (10x10) and make them smaler?
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,105
    nope, can't do it. You can always get rid of the toolbars and memorize the commandline version.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Full Member
    AutoCAD 2008
    Nov 2007
    46
    Too bad. I thougt it would be posible, beacose i came acros these site:
    http://www.upfrontezine.com/tailor/tailor03.htm
    And it is for very old release AC 13 but none of the commands work and .ini files are not on my computer.
    Too bad if newer releses don't have it anymore. Thanx for answer.
    Super Moderator Strix's Avatar
    not applicable
    Nov 2005
    Sheffield UK
    3,081
    I thought there was a choice of size
    or is it a windows setting?
    Find your new best friend at Rain Rescue
    If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
  5. #5
    Super Member GE13579's Avatar
    GE13579's Computer Details
    Windows XP
    Fujitso Siemens
    3.4Ghz
    Samsung 19" TFT
    Mechanical 2009
    Feb 2007
    North East England
    1,454
    OPTIONS- DISPLAY tab- check "Use large buttons for Toolbars".
    Ahhh... didn't fully read the post... sorry I'm afraid I don't know
  6. #6
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,105
    Quote Originally Posted by Strix View Post
    Icons of any application are raster image files with preset resolutions. only until very recently applications are starting to use a dynamic icon, or vector images for icons, and AutoCAD doesn't use them, nor gives you the option to change the size other than the standard and large icon settings. Of course this is to the best of my knowledge.
  1. i can not change the layer's setting in layer toolbar
    By bobi in forum AutoCAD Drawing Management & Output
    Last Post: 11th Apr 2013, 04:38 pm
  2. Custom Toolbar icon problem
    By Autocad Assassin in forum AutoCAD Drawing Management & Output
    Last Post: 11th Apr 2007, 01:00 am
  3. How do I change font size...muppet here
    By ODJapan in forum AutoCAD General
    Last Post: 21st Nov 2006, 05:57 pm
  4. tool palette icon size
    By TTALBOT in forum AutoCAD Drawing Management & Output
    Last Post: 7th Aug 2006, 09:41 pm
  5. Create/change new paper size
    By mittens in forum AutoCAD General
    Last Post: 28th Jul 2005, 12:48 pm
