Results 1 to 10 of 10
    Senior Member
    AutoCAD 2004
    Sep 2004
    Oregon, Usa
    208
    Default Rendering With Materials
    Hello, I haven't been around for a few years and I am glad this forum is still here!
    Probably an elementary problem I am having.
    I drew a simple 3D model of a bench in auto cad .
    Three extruded boxes that intersect one another but I did not use Union and they are still three seperate objects......a bench top and two legs.
    I wanted to render them in wood grain and suceeded.
    The problem is, I cannot figure out how to add materials to each object seperately.
    I figured out how to change the rotation of the material so I could show wood grain direction which realistically should be different on the top then on the legs of the bench.
    However, when I change the rotation of the material it changes on the entire drawing(is that called global?). I have tried to pick and select the individuall drawing objects before changing the material rotation but the change is still on every object in the drawing.
    Any help will be much appreciated!
    -Frank.
    Full Member DavidB's Avatar
    AutoCAD 2008
    Sep 2007
    ste-Julienne, Québec
    62
    someone correct me if i'm wrong but v2008 is Viz 2008 right?
    if so, again i might be wrong but it's close to 3ds max with access to sub-object ( vertex, edge,face etc)
    So just select the face/element you want to modify and simply add the selected material.
    its always in a 3ds max focus. If my answer isnt clear enought think of adding an image, it might help outto. erm.. help YOU out
    -D
    "Dieu est le point tangent de zéro et de l'infini."
    DAO-Quebec
    BordeleauDesign
    Senior Member
    AutoCAD 2004
    Sep 2004
    Oregon, Usa
    208
    Sorry about that.......my v stands for version........Auto Cad2004
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Asus VG248 24" Widescreen & Cintiq 21ux
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,316
    An easy fix would be to just set up two wood grain materials. One with the rotation set to 0 and the other with rotation set to 90.
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
  5. #5
    Senior Member
    AutoCAD 2004
    Sep 2004
    Oregon, Usa
    208
    Yeah, actually I did create a second wood material.
    My problem now is that I am unable to remove any material from the solids in the drawing.
    The command line seems to indicate that nothing is selected even though I invoke the remove materials command.......and then select the parts with the little paint brush and crossing window.
    As suggested, the drawing is attached to this message.
  6. #6
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,316
    I think the problem is your first material slot which is "Global". It's overriding everything. I usually leave that slot alone and just create new materials as I need them. Maybe try starting over again with a new drawing, leave the Global material slot alone and create new materials for your wood grain.
    Facebook:
  7. #7
    Senior Member
    AutoCAD 2004
    Sep 2004
    Oregon, Usa
    208
    Thankyou.
    That very thought crossed my mind and its nice to get a second opinion.
    -Frank.
  8. #8
    Senior Member
    AutoCAD 2004
    Sep 2004
    Oregon, Usa
    208
    For generall purposes and scenarios like a drawing with too much of an investment to toss out and start over.......just curious if any one knows if a command like "purge" would be able to delete the globally added materials so rendering could be begin anew?
    -Frank.
  9. #9
    Senior Member
    AutoCAD 2004
    Sep 2004
    Oregon, Usa
    208
    Yes.......silly not just to check for myself......global rendering cannot be purged.
    Still.......I wonder why?
  10. #10
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,316
    Quote Originally Posted by a1harps View Post
    You could just delete the map information from the material in the global material slot.
    Facebook:
  1. Materials for rendering - Library/Downloads?
    By Franco B in forum AutoCAD 3D Modelling & Rendering
    Last Post: 22nd Dec 2006, 10:47 pm
  2. additional rendering materials?
    By Randelli in forum AutoCAD Drawing Management & Output
    Last Post: 13th Nov 2006, 05:11 am
  3. Rendering materials rotation
    By kody_lawrence in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th Apr 2006, 01:37 am
  4. Rendering materials
    By Simo in forum AutoCAD 3D Modelling & Rendering
    Last Post: 3rd Dec 2004, 01:58 am
  5. faulty rendering materials
    By niall mcginnis in forum AutoCAD Drawing Management & Output
    Last Post: 13th Feb 2003, 06:14 pm
