Wipeout prints black form pdf's
scubadoo
Morning all,
When i use the wipeout command rather than background mask in the Mtext window and plot my layout as a pdf, for some reason the wipeout prints as a black block. Is there a solution for this?
Thanks
Dave
  • Replies 37
  • SLW210
    12
  • scubadoo
    10
  • GE13579
    4
  • SanMiguel
    3
whoops. my mistake, it is infact text mask that I'm using and not wipeout. so why does text mask print black?
i think my brain is going cos i've just handed my notice in!
Dave
Textmask just uses a wipeout by default so it's the same problem. You could try one of the other options in the masktype option but I don't recommend textmask anyway... leaves a very messy drawing when you come to edit it.
I have no idea- don't use it often for PDF's but just textmasked all the text on the drawing I'm currently working on, plotted to PDF and it's as I would expect, no visible black blocks...
I guess there must be a variable or something which controls opacity or something??? :?
unfortunately I don't think there's a solution to this problem.
You are probably correct.
Are you using AutoCAD's DWG to PDF.pc3 plotter driver? You will not be able to do it with that, I do not believe. Though the DWF>PDF might help.
You may find some third party Pdf plotters to plot the Wipeout/Textmask. You need to search the forum and see if anyone has done this.
Check this thread....
http://www.cadtutor.net/forum/showthread.php?t=17590
What are you using to plot to PDF?
I'm just saying what I'm using to plot to PDF...
When I go to plot, change the name to PDF Creator, the Plotter listed is that which I mentioned above in quotes...
