Results 1 to 9 of 9
    Forum Newbie
    AutoCAD LT 2002
    Nov 2007
    Germany
    2
    AutoCAD Problem with copy paste function AutoCAD
    Hello,
    I have got a problem with the copy and paste function.
    I try to copy objects (even only lines or cycles) from one file to an other. From some files it works but from other files I can not copy anything to an other file. The command _copyclip und _pasteclip is shown in the command window but nothing happens.
    It would be great to get some hints that could solve this problem.
    We use AutoCAD LT 2002 and AutoCAD 2008 witch MS Windows XP prof.
    Thank you in advance
    Andreas
    Super Member GE13579's Avatar
    GE13579's Computer Details
    Windows XP
    Fujitso Siemens
    3.4Ghz
    Samsung 19" TFT
    Mechanical 2009
    Feb 2007
    North East England
    1,454
    Strange, if you're copying from one file to another then copyclip shouldn't work at all... you should use COPYBASE instead.
    Super Member Hedgehog's Avatar
    Hedgehog's Computer Details
    XP sp 3
    Asus NCL-DE/1U E7520
    2 x Intel Xeon 7150N
    8 x Kingston KHX6400D2K2/4G 4 GB PC2-6400
    NVidia Quadro FX 5500 1 GB Pci-X 16
    2 x Seagte Barracuda 7200.10 320 GB HDD
    ViewSonic VP2290b-2Black 22” LCD
    MEP 2009
    Aug 2007
    Any Pub, Derbyshire, UK
    896
    This is a common, known problem between versions of AutoCAD... there is a fix available from Autodesk.. do a search
    GE... copyclip does work from one autocad dwg to another.
    Only the lonely only ... PhotoGallery / Music
    Super Member riga's Avatar
    AutoCAD 2007
    May 2007
    Switzerland
    723
    In the past it happend quite often that there was problems like the copy and paste in drawings created with a new version and saved in a format for previuos versions.
    You could try to install the SP1 for your 2008 (if you haven't yet)
    HAVE A NICE DAY
  5. #5
    Senior Member mahahaavaaha's Avatar
    AutoCAD 2009
    Jul 2007
    Finland
    340
    Hi,
    do you get any message when doing copyclip and pasteclip? As in X found? for copyclip and [ insertion point: for pasteclip
    Copyclip/paste work great between drawings...
    /Petri
    Life is what happens to you while you're busy making other plans.
    John Lennon (1940 - 1980)
  6. #6
    Windows XP
    Fujitso Siemens
    3.4Ghz
    Samsung 19" TFT
    Mechanical 2009
    Feb 2007
    North East England
    1,454
    Quote Originally Posted by Hedgehog View Post
    Lol I just realised I get confused quite a bit between copy and copyclip, sorry...
    (just use the button for copy usually)
  7. #7
    XP sp 3
    MEP 2009
    Aug 2007
    896
    Autodesk fix... http://usa.autodesk.com/adsk/servlet...linkID=9240618
    GE... no worries... I do that all the time
  8. #8
    Forum Newbie
    AutoCAD LT 2002
    Nov 2007
    Germany
    2
    Thank you all for your quick response!!
    Now I have to do my homework in oder to fix this buck.
    Thank you! I will report if this was successfull or not.
  9. #9
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,084
    The Hotfix needs to go on the machine that is back saving the file. You can use DWG TrueView 2008 to back save them yourself, or install DWGGateway from Solid works and open them in your 2002 without converting.
  1. AutoCAD 2004LT copy paste problem
    By jeffn in forum AutoCAD Drawing Management & Output
    Last Post: 20th Jul 2007, 10:53 pm
  2. MS Excel copy and paste problem.
    By firecad in forum AutoCAD Drawing Management & Output
    Last Post: 1st Aug 2006, 10:40 pm
  3. again copy-paste problem
    By goody in forum AutoCAD Beginners' Area
    Last Post: 30th Jun 2006, 02:38 pm
  4. copy and paste problem
    Last Post: 19th Jun 2006, 07:53 pm
  5. Copy -> Paste problem - Help
    By AutoCAD Slave in forum AutoCAD Drawing Management & Output
    Last Post: 29th Jul 2005, 12:47 pm
