Are you opening through ACAD or through Explorer?
I used to open more than two files at a time by highlighting then right click to select open but doesn't work anymore.
Please help.
I am opening the files from explorer.
hmmmm...did you see what your SDI is set to?
Sorry, I don't know what SDI is.
Does it open two sessons of AutoCAD or does it not work at all or does it only open one of the drawings?
"You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
I've found by opening through explorer I get another session of autocad
SDI is single document interface
from autocad:
Controls whether the program runs in single- or multiple-document interface. Helps third-party developers update applications to work smoothly with the AutoCAD multiple-drawing mode.
0 Turns on multiple-drawing interface.
1 Turns off multiple-drawing interface.
2 (Read-only) Multiple-drawing interface is disabled because an application has been loaded that does not support multiple drawings. SDI setting 2 is not saved.
3 (Read-only) Multiple-drawing interface is disabled because the user has set SDI to 1 and AutoCAD has loaded an application that does not support multiple drawings. (SDI was set to 1 before the application was loaded.) SDI setting 3 is not saved.
If SDI is set to 3, AutoCAD switches it back to 1 when the application that doesn't support multiple drawings is unloaded.
keep my regular autocad on 1, can have multiple dwgs open
landdesktop defaults to 3 so only 1 drawing at a time will be open
From File Explorer > Tools > Folder Options > File Types > highlight DWG in list, > Advanced
> highlight open > Edit... > (If open isn't there use New.. to create it.)
Application used to perform action:
"C:\Program Files\AutoCAD 2008\acad.exe" "%1"
Use DDE
checked
DDE Message:
[open("%1")]
Application:
AutoCAD.r17.DDE
OK > OK > Close
Modify the line showing
to reflect your path to acad.exe.
If you are using 2004 then the statement "AutoCAD.r17.DDE" will have to be changed to .r16. , I think r16, maybe r15 for 2004.
