Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
  1. #11
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    Drop this in an open drawing and see what you think. Just a quick little Dynamic Block I stuck together and I am a rookie when it comes to Dynamic Blocks.
  2. #12
    Senior Member New2CADmike's Avatar
    AutoCAD 2000
    Jun 2006
    Central California
    198
    How about this..Take your unexploded drawing and copy it to one side in a open area...explode the copy and then you will have both the exploded and the unexploded..The exploded drawing will have to have its parts moved away doing it the hard way,piece by piece..
    Using ACAD 2000
  3. #13
    Super Member Raggi_Thor's Avatar
    AutoCAD 2008
    Aug 2007
    Trondheim, NORWAY
    718
    This may work for you, but if youe have many parts you should make a copy on a frozen layer and then ExplodeView
    Code:
    Sub XplodeView()
    Dim e As AcadEntity
    Dim s As AcadSolid
    Dim Bmin As Variant 'Min point of bounding box
    Dim Bmax As Variant 'Max point..
    Dim CP(0 To 2) As Double 'Kind of CenterPoint, mid between Bmin and Bmax
    Dim Origo(0 To 2) As Double 'Origon: 0,0,0
    Origo(0) = 0: Origo(1) = 0: Origo(2) = 0
    For Each e In ActiveDocument.ModelSpace
    e.GetBoundingBox Bmin, Bmax
    CP(0) = (Bmin(0) + Bmax(0)) / 2
    CP(1) = (Bmin(1) + Bmax(1)) / 2
    CP(2) = (Bmin(2) + Bmax(2)) / 2
    If Not ActiveDocument.Layers(e.Layer).Freeze = True Then e.Move Origo, CP
    Next
    End Sub
    Sub ImplodeView()
    Dim e As AcadEntity
    Dim s As AcadSolid
    CP(0) = (Bmin(0) + Bmax(0)) / 4 'Now this is midway between CP and Origion..
    CP(1) = (Bmin(1) + Bmax(1)) / 4
    CP(2) = (Bmin(2) + Bmax(2)) / 4
    If Not ActiveDocument.Layers(e.Layer).Freeze = True Then e.Move CP, Origo
    Next
    End Sub
    Mvh, Kvedja, Kind Regards,
    Ragnar Thor Mikkelsen
    http://www.DESIGNDATA.no/English.htm
  4. #14
    Full Member
    AutoCAD 2008
    Nov 2007
    46
    How do i use the code? Must i have solids or blocks? I never used LISP before.
    Ever.
  5. #15
    AutoCAD 2008
    Aug 2007
    Trondheim, NORWAY
    718
    I tested with both solids and surfaces.
    There is no error control in my code it's just a fast example, it may not work in all drawings, but it worked in a few I tested.
    Press ALT+F11 to open the VBA editor in AutoCAD (or use menu Tools / Macro / Visual Basic Editor)
    Paste the code from above, see image belowe.
    Then use the command VBARUN or make two command buttons, with macros like
    ^C^C-vbarun;XplodeView
    and
    ^C^C-vbarun;ImplodeView
  6. #16
    Full Member
    AutoCAD 2008
    Nov 2007
    46
    Actually i must say these works like a charm. Great job really posting these.
    When i explode a small disortion is presented for some solids (minimum displacement for parts). I guess beacose of mid point and distance frome it.
    But for presentation purposes these is yust the best.
    How could i create buttons as you suggested? A command Vbarun works like a charm, but i like to try it with a button to.
    Edit: I have created a button in customize and add ^C^C-vbarun;XplodeView ... and again it works like a charm.
    Thanx x 2
  7. #17
    Super Member riga's Avatar
    AutoCAD 2007
    May 2007
    Switzerland
    723
    Use the CUI command to create 2 new commands and assign to them the 2 macros reported in the post of Raggi_Thor.
    You can edit the buttons names obviously.
    Then you can create a new toolbar and drag the 2 new commands into it or just drag them into an already existing toolbar.
    This link can be usefull and more clear
    http://www.ellenfinkelstein.com/Auto...m_command.html
    HAVE A NICE DAY
  8. #18
    Forum Newbie
    AutoCAD 2008
    Sep 2008
    7
    I have been looking for some time to find a bit of code to do this!!! Is there a way to get it to explode in the X & Y direction? It only seems to be pulling the parts in one axis. Again, thank you this is great stuff!
  9. #19
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Haven't seen Raggi since October of 2012. You might have to wait a while for an answer.
  1. Convert "body" to "Solid"
    By powerdog in forum AutoCAD 3D Modelling & Rendering
    Last Post: 12th Jun 2007, 04:11 pm
  2. "LINK template" icons "greyed out" -why?
    By Chrisjpritchard in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Mar 2007, 10:25 pm
  3. "Explode" 3D object into flat cutting pattern shap
    By VBAjedi in forum AutoCAD Drawing Management & Output
    Last Post: 13th Mar 2006, 11:24 am
  4. "Union" Meshes or "Slice" 3D Mesh
    By Peter31712 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Apr 2004, 11:11 pm
  5. Why have solids started "bleeding"?
    By Cadastrophic in forum AutoCAD 3D Modelling & Rendering
    Last Post: 20th Mar 2004, 11:09 pm
