Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
    Full Member
    AutoCAD 2008
    Dec 2007
    37
    Default Dimstyle/Radius in 2008
    I have recently made the jump from Acad 2002 to 2008.
    I have found that when positioning a radius dimension inside a rad, an arc is drawn in and the dimension attaches to it.
    Dopes anyone know how to override this?
    Super Member CADken's Avatar
    CADken's Computer Details
    Microsoft Windows 7 Ultimate
    Toshiba Satellite A135
    Intel Pentium T2080 @ 1.73GHz, 1733 Mhz, 2 Core(s), 2 Logical Processor(s)
    Slot 1: 1GB DDR Slot 2: 1GB DDR
    Toshiba 110GB, Maxtor External HD 120GB
    Notebook Monitor + 22" NEC AccuSync LCD223wxm
    AutoCAD 2010
    Jun 2006
    East Coast - Pennsylvania
    828
    dimension edit tool?
    Fireman | Draftsman | Fabricator
    Running Windows 7 with AutoCAD 2010
    the Battalion East Side Pride
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,117
    Quote Originally Posted by mikef View Post
    type DIMSTYLE to bring up the Dimension Style Manager. click the style your using and press the Modify button. go to the Symbols & Arrows tab, and under the Arc Length Symbol choose None. That should do it for ya.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Full Member
    AutoCAD 2008
    Dec 2007
    37
    Neither of those worked I'm afraid.
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,108
    Can you put up a screenshot?
  6. #6
    Super Member riga's Avatar
    AutoCAD 2007
    May 2007
    Switzerland
    723
    Are you sure you are not using the arc lenght (_dimarc) instead _dimradius?
    I know it sounds stupid, but I can't reproduce your problem on my PC and so that doubt comes to my mind (I think _dimarc doesn't exist in 2002 v.)
    HAVE A NICE DAY
  7. #7
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,108
    Well I have duplicated it, but it was while using the radius dimension with out an arc associated with it and rotating a radius dimension past the end of the arc. Just go into Properties and turn the Extension line off, this will relocate your dimension back onto the arc.
  8. #8
    Full Member
    AutoCAD 2008
    Dec 2007
    37
    No option to turn extension off, made length zero but no effect.
  9. #9
    Full Member
    AutoCAD 2008
    Dec 2007
    37
    Quote Originally Posted by SLW210 View Post
    Not sure how to do that, Ill work on it.
  10. #10
    Full Member
    AutoCAD 2008
    Dec 2007
    37
    Radius Problem.dwg
    Attached is an example of the problem.
  1. preventing dimstyle overrides...
    By hazardman in forum AutoCAD Drawing Management & Output
    Last Post: 16th Mar 2012, 05:02 pm
  2. Dimstyle Question
    By JaketheMan in forum AutoCAD General
    Last Post: 30th Nov 2007, 11:30 pm
  3. dimstyle help
    By Winfield in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Jul 2007, 09:56 pm
  4. Command aliases and Dimstyle overlap - need to fix
    By OBRAS0118 in forum AutoCAD Drawing Management & Output
    Last Post: 1st Jun 2007, 01:48 am
  5. importing entire dimstyle
    By a_differently abled_draft in forum AutoCAD Beginners' Area
    Last Post: 26th Feb 2006, 01:18 pm
