Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 22
  1. #11
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    Quote Originally Posted by mikef View Post
    No option to turn extension off, made length zero but no effect.
    Just go into Properties and turn the Extension line off, this will relocate your dimension back onto the arc.
    Here are the steps and results.....
  2. #12
    Full Member
    AutoCAD 2008
    Dec 2007
    37
    I don't seem to have the same options in properties that you have.
    This is Acad 2008.
  3. #13
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    That is odd, mine is 2008 as well, and as you can see, I have that in my properties. Try turning it off in _DIMSTYLE by making New dimension for Radius.
  4. #14
    Full Member
    AutoCAD 2008
    Dec 2007
    37
    I am not getting the option to suppress ext line 1, it's greyed out.
  5. #15
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    Tried setting _DIMSE1 to ON in your drawing and then Update dimension and select your dimension, hit Enter.
  6. #16
    Full Member
    AutoCAD 2008
    Dec 2007
    37
    Well, that got rid of the arc, unfortunately the dimension is still in the same place.
  7. #17
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    Where do you want the dimension?
  8. #18
    Full Member
    AutoCAD 2008
    Dec 2007
    37
    I wanted it attached to the radius I was measuring, it's still pointing to where the extension arc used to be.
  9. #19
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    Select it and move the grip on the arrow. Mine snapped to the arc when I did update. Seems like something is wrong with your system, you should have had all those options I mentioned before.
    Do you have all the latest Updates and Service Pack?
  10. #20
    Full Member
    AutoCAD 2008
    Dec 2007
    37
    Loaded it just a couple of weeks ago, it's on servicepak 0, I see there are a few updates avalable, I will try that out next.
    Thanks a lot for your help.
    Just checked, one of the fixes in servicepak 1 is specifically for this problem, never would have thought 2008 would be out of date befor I even loaded it!
  1. preventing dimstyle overrides...
    By hazardman in forum AutoCAD Drawing Management & Output
    Last Post: 16th Mar 2012, 05:02 pm
  2. Dimstyle Question
    By JaketheMan in forum AutoCAD General
    Last Post: 30th Nov 2007, 11:30 pm
  3. dimstyle help
    By Winfield in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Jul 2007, 09:56 pm
  4. Command aliases and Dimstyle overlap - need to fix
    By OBRAS0118 in forum AutoCAD Drawing Management & Output
    Last Post: 1st Jun 2007, 01:48 am
  5. importing entire dimstyle
    By a_differently abled_draft in forum AutoCAD Beginners' Area
    Last Post: 26th Feb 2006, 01:18 pm
