Results 1 to 6 of 6
    Full Member Ozymandias's Avatar
    AutoCAD 2009
    Nov 2007
    Hampshire
    52
    Default Using lisp with blocks
    Hey guys me again,
    I Have A lisp that gives me the ability to generate unique numbers with a stated precurser I.e. 04nwo1-02 -03 -04 etc.
    Now the thing that I would like to do with this (although I highly doubt you can) is to be able to insert it into a field inside a block, so that when I insert a block each time you get a unique number.
    its basically a desk numbering system. I have the blocks already set up with a field to state the floor number but I need to be able to have the area and number (4 areas in total) so if you have another idea that would be helpfull I would greatly appreciate it as it would save me days renumbering every desk by hand.
    AutoCAD 2009
    Nov 2007
    Hampshire
    52
    I take it from the silence no one knows how this can be done? the only other way I can think of is to have all the numbers in an external xcel sheet and refer blocks individually (attach as attribute) to the references I know this can be done but dont know how to do that.
    If no one knows are there any books out there that could help ?
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,633
    So you just want to insert a block and have an attribute filled out using an incremental number?
    That shouldn't be too difficult. You could store the last (or next) number in a dictionary - and just refer to it when you insert the next block.
    AutoCAD 2009
    Nov 2007
    Hampshire
    52
    ive not come accross dictionarys and refering to them before .
    I have just looked it up in the F1 but its not very helpfull on the subject. Thanks for the help.. ill continue to look around to see what you are refering to.
  5. #5
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Look here for an explanation of dictionaries
    http://www.afralisp.net/lisp/dict.htm
  6. #6
    AutoCAD 2009
    Nov 2007
    Hampshire
    52
    thanks definately worth investigating..
  1. Lisp colour change for all layers and blocks
    By hyposmurf in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th May 2013, 02:16 pm
  2. Lisp for inserting blocks without basic prompts
    By Towel in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Oct 2007, 03:24 pm
  3. Blocks, Details, LISP Routines and More...
    By good_m in forum Useful Links
    Last Post: 30th Mar 2006, 08:06 pm
  4. redifining blocks in LISP
    By dimtick in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Dec 2005, 06:36 pm
  5. Lisp for counting blocks?
    By Bloke in forum AutoCAD Drawing Management & Output
    Last Post: 9th Oct 2003, 06:24 am
