Results 1 to 3 of 3
    Forum Newbie
    AutoCAD 2008
    Dec 2007
    3
    Default Setting base angle 0d00'00" to an arbitrary line ?
    I've only been using Autocad for a couple weeks so I apologize if the answer to this question is really obvious.
    Here's my problem: I've taken some measurements around a building with a theodolite and everytime I moved it, I would set the 0 angle to the previous spot I was taking measures from. So now I have 6 points around the building each with 4-5 measuring lines that start from it (distance and angle) but every point has its own 0d00'00" angle...
    I can draw the first station without a problem because the initial angle can be the default East 0d00'00", it doesn't really matter... but after that, I can't figure out how to like, select a line and tell autocad "this is your new 0 for now" then draw the field data, and repeat that with each point.
    I hope this makes sense, let me know if you need clarifications.
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    You could rotate your UCS [UCS > New > Object] and use your last drawn traverse leg as the object to align the UCS.
    Forum Newbie
    AutoCAD 2008
    Dec 2007
    3
    Exactly what I was looking for.
    Thanks!
  1. Setting BASE ANGLE to North - Does not appear to work?
    By Tempest in forum AutoCAD Beginners' Area
    Last Post: 29th Apr 2015, 04:33 pm
  2. how to draw line from base point
    By smiles in forum AutoCAD Beginners' Area
    Last Post: 10th Oct 2007, 01:55 am
  3. "Copy with base point" with spesific coords
    By Siberian in forum AutoCAD General
    Last Post: 2nd Apr 2007, 07:44 pm
  4. setup - setting "working directory"
    By lola in forum AutoCAD Beginners' Area
    Last Post: 12th Jan 2007, 10:37 am
  5. "open file" setting changed somehow...
    By MostlyLqd in forum AutoCAD Drawing Management & Output
    Last Post: 19th May 2006, 10:46 pm
