When I try to put a breakline in my drawing , The program will not allow me to enter a size of 1" an extension of 1" within a 1'-2 3/8" distance. I get an error that says the endpoint and start point are too close together. When I measure the distance that I am allowed to draw a breakline in it is about 21'-0" and the extension is 8'-0" long. my LTS is set at 50 ??? i set it at 1 and it made no difference.
When you start the command on the command line you should see the attached prompt.
Which value do you have setted there for Size and extension? Playing with those two variabkes coul be usefull to find a solution
HAVE A NICE DAY
Maybe you could post a screen shot or a portion of your drawing, I am having no problems.
On the two screenshots attached see an example of the dimensions involved. I am trying to put the breaksymbol between the two vertical lines that are 1'-3" apart. as you can see the taskbar is saying the distance is too close together to put a breakline with 1" extension and a size of 1" in that 1'-3" dimension. How can that dimension be to close? the ltscale is 1" are there any more parameters to check?
The first screenshot is an enlargement. the 2nd is a zoom to the 1'-3" dimension area. This is an example made on the modelspace of the same drawing that will not accept the breakline symbol
Try reading these instruction from the LISP. I think you should check your DIMSCALE.
Code:;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ; BREAKLINE ;This routine allows you to quickly create breaklines by selecting two points and ;optionaly a third point to specify a non-midpoint location for the break symbol. ; You can configure BREAKLINE settings such as break symbol to use, the size and ; extension distance by pressing "Enter" at the first prompt. ; You can customize this feature in several ways: ; ; Break symbol BLOCK - ; The default break symbol is a drawing called BRKLINE.DWG that is ; provided in the [ACADDIR..]\EXPRESS directory. However, if ; you wish, you can use your own custom symbol by defining a block ; you like and then setting the options in BREAKLINE to use that block. ; There is only one requirement that must be met in order for BREAKLINE to ; use your custom block. The block must contain two POINT objects that reside ; on the DEFPOINTS layer. These points are used for aligning the symbol along ; a breakline and for scaling it. ; NOTES ON DEFPOINTS: If your drawing does not already have a defpoints layer ; you can create it. Also note that points on the defpoints layer will not ; show on plots and these points also will not display according to pdmode ; settings. (Points on the defpoints layer always display as a dot.) ; ; Break symbol SIZE - ; In the options sub-prompt there is a "Size" option that allows you to control the ; scale that the breakline symbol will appear at. This value is scaled by the current ; dimscale setting in your drawing. (This analagous to the behavior of many DIM ; variables such as DIMTXT and DIMEXE.) ; The overall size of the symbol is affected by the distance between the ; defpoints contained in the break symbol block that is used and the ; relationship between dimscale and the BREAKLINE size setting. ; The overall size is described by the expression: ; A*S*D ; Where A is the distance between the defpoints in the block as created. ; S is the BREAKLINE size setting ; D is the current DIMSCALE setting. ; ; For example: Using the default block, BRKLINE.DWG, which has a distance between ; defpoints of 1, and a BREAKLINE size setting of 0.5 and dimscale ; is set at 48. ; The resulting distance between defpoints will be 24. (1 * 0.5 * 48) ; ; Breakline extension distance - ; BREAKLINE will create a line that extends beyond the two points picked by a ; specified amount. This extension distance is similar to the DIMEXE extension ; distance for dimension entities. Similarly, the value is also affected by ; the current DIMSCALE setting. ;
