Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 57
  1. #11
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    Even easier way. Do your dimension from Endpoint to Endpoint, then _DDEDIT and select the dimension text. Delete the dimension text and use Insert Field, then Object. Select the polyline and then select length and set the rest of the options to suit. If you move the endpoints and use Associative Dimensions the dimensions will follow, to update the dimension I just use DDEDIT click on the Dimension Text and then when the editor opens just hit OK and the dimension will update. I hope this helps.
  2. #12
    Forum Deity NBC's Avatar
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    Nice solution AGM.
    The big question is, is it what the thread starter wants ?
    Here's hoping he comes back and leaves feedback.
    Life's constantly changing - keep up or get left behind
  3. #13
    Super Member riga's Avatar
    AutoCAD 2007
    May 2007
    Switzerland
    723
    Nice one really. I didn't think at use of FIELD in dimension text
    I think you've solved the issue perfectly and we will have another user satisfied
    HAVE A NICE DAY
  4. #14
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    Well, let me explain how I came up with that. I decide to work on making a Dynamic Block during my lunch break. So I am thinking about how to set up an attribute (I suck at attributes and really had to do some thinking, nearly set off the smoke detectors ). I got the attribute figured, finally. Then I decide maybe a LISP, that's when the came on. MTEXT has insert fields. You see how I sorted it. Still might work on a LISP and Dynamic Block when I get time.
    Thanks for the compliments fellows. I hope that is what was asked for. It is just a little bit of work to start, but easily updates and for a mouse clicker like me, easier than text override and adding the lengths.
  5. #15
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    Text overrides should be banned imo !
    They are almost as bad as exploding hatches !
  6. #16
    Senior Member daveyboyd's Avatar
    AutoCAD 2010
    Apr 2006
    Liverpool, UK
    134
    That's a quality work around and I appriciate the fact you've stressed over it somewhat but its not quite what I was looking for, the actual text displayed is not really the important factor it was more the dog-legged dimension line I was really hoping to display, but thank you for your efforts.
    Dave
  7. #17
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    Dave, it can be done using a lisp. But please don't ask me to write one for you.
    But if you grovel enough, and because it is a weekend, and because you spent some time here, I just may be compelled to help you out.
  8. #18
    AutoCAD 2010
    Apr 2006
    Liverpool, UK
    134
    Alan, that is very kind of you, I was only thinking the other day about my time in Oz, I had Connel Wagner email me asking if I wanted to come back and and work for them, maybe in a couple of years I will, who knows. This year I will be freezing my nuts off in Liverpool, last year I was in 38 degree heat down your end in Cairns, bit of a contrast!
    Thanks for all your help guys, including you Alan, your great (is that enough grovelling )
  9. #19
    Map 3D 2009
    Jun 2006
    4,181
    Yeah that grovelling should do it. But not tonight. I have Tiger whacking me at the moment trying to sort out another lisp, god knows how long that will take.
  10. #20
    Super Member happyunited's Avatar
    AutoCAD 2010
    Jun 2006
    Manchester, England
    588
    while we are on the suject of dims, i have my precision set to 0.000 in my simstyle but yet my dims keep coming out at 0.0 what am i doing wrong?
    thanks
    Chris
  1. command line up arrow question, and grip edit distance question
    By Rebel in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Jun 2008, 03:15 pm
  2. dimensions
    By Littlemouse in forum AutoCAD General
    Last Post: 16th Aug 2007, 04:45 pm
  3. dimensions
    By Iris Yilmaz in forum AutoCAD Beginners' Area
    Last Post: 6th Aug 2006, 05:08 pm
  4. dimensions
    By sentinel in forum AutoCAD Beginners' Area
    Last Post: 16th Jul 2006, 05:12 pm
  5. Question regarding Dimensions
    By Xaquin in forum AutoCAD General
    Last Post: 24th Aug 2005, 02:31 pm
