Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 57
  1. #21
    Forum Deity NBC's Avatar
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    what is your DIMRND value set to ?
    Life's constantly changing - keep up or get left behind
  2. #22
    Super Member happyunited's Avatar
    AutoCAD 2010
    Jun 2006
    Manchester, England
    588
    Quote Originally Posted by NBC View Post
    dimrnd = 0.00 ?>?
  3. #23
    AutoCAD 2010
    Jun 2006
    Manchester, England
    588
    just looking if the value is 4.12 then it will dim it at 4.12 but if it is 4 it will dim it at 4 and not 4.00
  4. #24
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    strange indeed.
    i'm not sure what to suggest right now, any offers ?
  5. #25
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    Yeah, I've had that happen before. Sorry, Happy, can't remember what I did to fix it.
    Maybe set it in DDIM, UNITS, and LUPREC?
  6. #26
    AutoCAD 2010
    Jun 2006
    Manchester, England
    588
    Ok Another Question, I Ahve Done A Dimension But I Dont Want Any Text On That Dim As I Want To Type My Own Its A Tricky Bit Of Text Is There Anything I Can Put In Text Overwrite So No Text Displays?
  7. #27
    Map 3D 2009
    Jun 2006
    4,181
    Just type "A", and edit it to suit what you want. That way it will be placed correctly and centered.
    If you really don't want text there, just hit the space bar.
  8. #28
    AutoCAD 2010
    Jun 2006
    Manchester, England
    588
    Quote Originally Posted by Alan Cullen View Post
    WHERE DO I TYPE "A"?
  9. #29
    AutoCAD 2010
    Jun 2006
    Manchester, England
    588
    this is what i want- the note in white to be part of the dim but that is proving difficult!!
  10. #30
    Map 3D 2009
    Jun 2006
    4,181
    When you do a dim, it asks you for the dimension required, but defaults to the dimmension it belives it should be. so if you hit ENTER, that default dimmension is returned.
    Just accept that default dimmension, then edit it (double click it) (should be mtext) and change it to what you want.
    Edit it, then move/rotate it to position.
  1. command line up arrow question, and grip edit distance question
    By Rebel in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Jun 2008, 03:15 pm
  2. dimensions
    By Littlemouse in forum AutoCAD General
    Last Post: 16th Aug 2007, 04:45 pm
  3. dimensions
    By Iris Yilmaz in forum AutoCAD Beginners' Area
    Last Post: 6th Aug 2006, 05:08 pm
  4. dimensions
    By sentinel in forum AutoCAD Beginners' Area
    Last Post: 16th Jul 2006, 05:12 pm
  5. Question regarding Dimensions
    By Xaquin in forum AutoCAD General
    Last Post: 24th Aug 2005, 02:31 pm
