I have a program that I want to try out. It's called cylinderD.VLX. I've loaded it successfully, but don't know how to run it. I've tried typing its name in the command line, but this doesn't work.
Can anyone tell me with the procedure please?
I'm sure you said "Hurry up and DELETE your work".
AutoCAD 2004, Inventor 8.
AMD Athlon 64 FX-55, 3GB RAM, NVIDIA Quadro4 980XGL, Windows XP Pro.
try loading it again and keep an eye on your command line ~ it should tell you what to type to run it. Hit F2 if needed.
Since it's a VLX, you won't be able to get to the source code to see what the command is.
do you have any other documentation with it ? whoever supplied it should have included a text file or something
ResourceCAD.... the Resource for your CAD Solutions
A good program should tell you how to start it![]()
It's nice to be nice, but sometimes is nicer to be evil!.
Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
