Results 1 to 4 of 4
    Forum Newbie
    not applicable
    Dec 2007
    2
    Default Where to place the ctb file?
    Hello all!
    I have ACad r-14 installed in my computer, however I have a client using 2007 (I believe) so I'm just using True View to open the dwgs and (hopefully) print.
    My question is this. Where do I place the .ctb file so that the pen style shows up in the plot dialog box? Right now it just says "(missing)"...Any help on this would be greatly appreciated.
    Thanks in advance,
    Joda
    Super Member riga's Avatar
    AutoCAD 2007
    May 2007
    Switzerland
    723
    Sorry but I not work with R14 since long time so I can't remember well:
    In the File menu there is not the Plot styles manager? If it is there it will open the folder where your ctb and stb files are saved and it's there you have to copy the new one.
    But as I said I could be wrong
    HAVE A NICE DAY
    Senior Member GhostRider's Avatar
    GhostRider's Computer Details
    Windows10
    Dell XPS
    Dell
    Intell Core 2 DUO 2.8ghz
    32 GIG
    Nvidia
    160 Gigger
    Dual Dell
    Architectural
    GhostRider's Discipline Details
    Residential Engineering/Contracting
    Architectural
    AutoCAD 2018
    Aug 2007
    N. Carolina
    405
    In the options menu, check the files TAB and see what your "Plot Style Table seach path is.
    They should be stored there.
    So many commands, so little time....
    Forum Newbie
    not applicable
    Dec 2007
    2
    Quote Originally Posted by GhostRider View Post
    Thank you so much...this worked perfectly!
  1. Xref Edit at Place!!
    By CadCodes in forum AutoCAD Beginners' Area
    Last Post: 2nd May 2007, 01:52 pm
  2. Edit blocks in-place
    By nelsonrocha47 in forum AutoCAD Beginners' Area
    Last Post: 2nd Jun 2006, 10:45 pm
  3. place the file location on a drawing?
    By radiat10n in forum AutoCAD General
    Last Post: 4th Nov 2005, 05:06 pm
  4. This might not be the place to ask but...
    By TateCE in forum AutoCAD Drawing Management & Output
    Last Post: 28th May 2005, 07:46 am
