It works in 2008
do SSX command exist in 2007?![]()
It works in 2008
Yes, SSX has been around since R14. Command Reference List
"Work Smart, Not Hard"
Click to View My Portfolio ( Updated 05/21/2013 ) ---> http://www.rdeweese.com/
oh cool - a cryptic thread![]()
what does SSX do?
Find your newbest friend
at
Rain Rescue
If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
That's an interesting (old?) command. I wrote a small lisp recently to do much the same thing (before I knew about that one):
Code:;;-------------------------------------------------------------------------- ;; SELSET.LSP CREATE A SELECTION SET WITH MULTIPLE SELECTIONS ;;========================================================================== ;; ;;START COMMAND .............. SELSET ;;SELECTION SET NAME.............. ss ;;TO RECOVER SELECTION SET........ !ss ;; ;;WRITTEN BY: ALAN CULLEN OCTOBER 2007 ;; ;;-----------------------------MAIN PROGRAM------------------------------ (defun c:selset () (setq test 1) (prompt "\n Select objects....") (setq ss (ssget)) (while test (prompt "\n Select next set of objects....") (setq ss2 (ssget)) (if (/= ss2 nil) (progn (setq number (sslength ss2)) (setq counter 0) (repeat number (setq name (ssname ss2 counter)) (setq counter (+ 1 counter)) (ssadd name ss) )) (progn (setq test nil) ))) (prompt "\n Use !ss to recover the selection set....") )
SSX command serves primarily to filter a selection set based on object properties. Since the advent of "filter" & "qselect", SSX probably has few advantages.
Alan, as far as I could tell your routine combines 2 selections sets, & gives them a variable name that can be retrieved for use in another command.
Thanks, Carl, but only one selection set called ss. It was a quick and dirty to help a member a little while ago. I've never actually used it. Old habits die hard, so I still use (setq ss (ssget)).![]()
SSX is an Express Tool, if you have Express Tools loaded you should have it. It is command line only.
