+ Reply to Thread
Results 1 to 6 of 6
Thread: osnap problem
  1. #1
    Full Member DavidB's Avatar
    Using
    AutoCAD 2008
    Join Date
    Sep 2007
    Location
    ste-Julienne, Québec
    Posts
    62
    Default osnap problem
    hello, i have a strange problem with my osnap.
    if i use it in a 3d view (iso or not) it snap ok but when i wha to use it in a 2d view. (top,left ect. ) it goes snap at 0,0 coordinate.
    ie. i have a set of truss at 3 m of the ground. i have to snap the trust to a beam, if i'm in a top view BAM it goes snap a the bottom of the beam.
    is there a option i need to check or i should always snap in 3d view?
    "Dieu est le point tangent de zéro et de l'infini."
    DAO-Quebec
    BordeleauDesign
  2. #2
    Super Member GE13579's Avatar
    Computer Details
    GE13579's Computer Details
    Operating System:
    Windows XP
    Computer:
    Fujitso Siemens
    RAM:
    3.4Ghz
    Monitor:
    Samsung 19" TFT
    Using
    Mechanical 2009
    Join Date
    Feb 2007
    Location
    North East England
    Posts
    1,454
    Default
    I think UCSFOLLOW to 1 or type PLAN after you've changed your viewpoint?
  3. #3
    Using
    AutoCAD 2008
    Join Date
    Sep 2007
    Location
    Posts
    62
    Default
    thanks GE13579 but it doesnt seem to work. but these are interessting command .
    thing is i think i still work with 3ds max workflow in mind so maybe thats the bug. in 3ds max you have 3 type of snap. 2d - 2.5D - 3D .
    • 2D = like the name say it work only in 2d for a plan or an elevation. bug is it wont snap if the object and snap point arent on the same axe
    • 3D = like Osnap .perfect for any 3d view with the problem i talking about for Acad. if you go on a plan view or elevation it goes same toany point closer to 0
    • 2.5D = What i try to achieve in ACAD. it can snap to a point in 3d but the object stay in 2d. Like my truss example. If you have truss 3m in air and you are in top view, even if you snap the bottom of your beam the beam will stay in its position in z axis but will go snap the beam in X & Y
    long explaination for a small problem
    DAO-Quebec
    BordeleauDesign
  4. #4
    Super Member chulse's Avatar
    Computer Details
    chulse's Computer Details
    Operating System:
    Windows 7
    Computer:
    Lenovo W701 mobile workstation
    RAM:
    12GB
    Graphics:
    NVIDIA Quadro FX 3800M
    Monitor:
    17" wide screen laptop w/ 22" acer
    Discipline
    See details...
    chulse's Discipline Details
    Occupation
    Conservation Planner/Arborist
    Discipline
    See details below.
    Details
    Tree Preservation Planning for civil design and developent
    Using
    Civil 3D 2013
    Join Date
    Jul 2007
    Location
    Front Royal, Virginia
    Posts
    1,312
    Default
    is OSNAPZ what you're after?
    from help:
    Type:Integer
    Saved in:Not-saved
    Initial value:0
    Controls whether object snaps are automatically projected onto a plane parallel to the XY plane of the current UCS at the current elevation.
    0 - Osnap uses the Z-value of the specified point
    1 - Osnap substitutes the Z-value of the specified point with the elevation (ELEV) set for the current UCS
    Cary Hulse
    www.TreePreservationPlan.com
    www.Pack53.info
  5. #5
    Using
    AutoCAD 2008
    Join Date
    Sep 2007
    Location
    Posts
    62
    Default
    wow thank . exactly what i was looking for.
    once again Cadtutor user same my life
    DAO-Quebec
    BordeleauDesign
  6. #6
    Computer Details
    Operating System:
    Windows 7
    Computer:
    RAM:
    12GB
    Graphics:
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    Civil 3D 2013
    Join Date
    Jul 2007
    Location
    Posts
    1,312
    Default
    cool-
    I don't do much 3d so I wasn't sure if that was what you were looking for...
    Cary Hulse
    www.Pack53.info
Similar Threads
  1. Lame OSNAP problem
    By petersilk in forum AutoCAD Drawing Management & Output
    Last Post: 20th Mar 2013, 07:49 am
  2. osnap
    By rookie37 in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Sep 2007, 03:13 pm
  3. Osnap to the end of a leader
    By WannaBeCader in forum AutoCAD Drawing Management & Output
    Last Post: 18th Nov 2005, 02:40 pm
  4. osnap
    By mechdraw1 in forum AutoCAD Beginners' Area
    Last Post: 8th Aug 2004, 09:45 pm
  5. OSNAP
    By Dan in forum AutoCAD Beginners' Area
    Last Post: 22nd May 2003, 08:42 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
