Results 1 to 7 of 7
Thread: plotter cleanup
    Full Member DavidB's Avatar
    AutoCAD 2008
    Sep 2007
    ste-Julienne, Québec
    62
    Default plotter cleanup
    hello all. after a small search i come to you for help.
    Is there a way to clean/remove plotter from the list Acad offer you before plotting?
    i have many custom plotter and having to scroll between unused one is making me loose time. For example :dwgtoPDF.pc3 or publishtoJPGweb.pc3 are no use for me right now.
    So ? any idea how to kick those out of the list? should i only remove the .PC3 in the plotter directory ( when i'll find it ) or its in the option
    "Dieu est le point tangent de zéro et de l'infini."
    DAO-Quebec
    BordeleauDesign
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,134
    Go to File>Plotter Manager and select and delete the ones you do not want.
    Senior Member mahahaavaaha's Avatar
    AutoCAD 2009
    Jul 2007
    Finland
    340
    Hi,
    you can also check the "Hide System Printers" option in Options--Plot and Publish.
    /Petri
    Life is what happens to you while you're busy making other plans.
    John Lennon (1940 - 1980)
    AutoCAD 2008
    Sep 2007
    62
    thank guys. i should knew it was that easy .
    DAO-Quebec
    BordeleauDesign
  5. #5
    Forum Newbie
    AutoCAD 2008
    Jan 2008
    1
    hi, guys, anybody can give me a clue how to publish a few dwgs to pdfs in one time? I tried, and the plot log files said no errors, but i just couldn't find where all those pdfs were. I am using 2008.
    thanks
  6. #6
    AutoCAD 2009
    Jul 2007
    Finland
    340
    Hi,
    if you're using the default DWG to PDF.pc3, it's creating a multipage PDF for you. (only one file created right?). The place for this file can be determined in Publishing Options -- Default Output location. I'm still trying to figure how to get it to print into separate files...
    Good Luck
    Petri
    BTW, you should've created a new thread for this...
  7. #7
    AutoCAD 2009
    Jul 2007
    Finland
    340
    Duh,
    PUBLISHCOLLATE = 0 --separate files... Why didn't the DWF-setting for separate files affect the PDF's? Silly as the locationparameter was the same...
    /Petri
  1. Drawing Cleanup Utility Now Available on Autodesk Labs
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 3rd Jan 2008, 05:22 am
  2. AutoCAD Drawing Cleanup Utility "DCU" on Autodesk Labs
    Last Post: 11th Oct 2007, 10:30 pm
  3. Easy wall cleanup solution?
    By Noahma in forum AutoCAD General
    Last Post: 26th Aug 2007, 05:08 am
  4. Wall Cleanup
    By Cad Sponge in forum AutoCAD Drawing Management & Output
    Last Post: 21st Aug 2007, 12:34 am
  5. drawing cleanup for dxf
    By nwmjdp in forum AutoCAD Beginners' Area
    Last Post: 4th Oct 2005, 05:01 am
