Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: Solview
    Junior Member
    AutoCAD 2008
    Jan 2008
    14
    Default Solview
    I'm new to modelling. I am using Acad 2008. When I extract a drawing using Solview, the drawing configuration is 3rd angle. Is there a setting I can alter to make this 1st angle.
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    That's a good question. Not that I am aware of in vanilla AutoCAD. In MDT, Inventor, SolidWorks and others there is a simple format switch.
    In AutoCAD I suspect the best you can do is move the viewports after creation.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    Senior Member
    Secretagdan's Computer Details
    Windows 7
    Custom
    8.00 GB
    NVIDIA Quadro 2000
    INTEL SSDSC2MH120A2
    (2) Samsung 226BW 22" Monitor(s)
    Manufacture
    Secretagdan's Discipline Details
    Lead Detailer
    Manufacture
    I draw stuff people build it.
    AutoCAD 2012
    Oct 2007
    Hillsboro, OR
    229
    All that you need to do, is in model space, set you ucs to the view you want. Then use you solview command.
    Junior Member
    AutoCAD 2008
    Jan 2008
    14
    Quote Originally Posted by Secretagdan View Post
    Hi, if i do this, then it just returns a 3rd angle projection of whichever UCS I've set.
    Am I missing something ??
    Thanks for the help, it's appreciated, Keith.
  5. #5
    Senior Member
    Windows 7
    Custom
    8.00 GB
    NVIDIA Quadro 2000
    INTEL SSDSC2MH120A2
    Manufacture
    Lead Detailer
    Manufacture
    AutoCAD 2012
    Oct 2007
    Hillsboro, OR
    229
    Command: SOLVIEW
    Enter an option [Ucs/Ortho/Auxiliary/Section]: U
    Enter an option [Named/World/?/Current] <Current>: C
    Enter view scale <1.00000>: 1/24
    Specify view center:
    Specify view center <specify viewport>:
    Specify first corner of viewport:
    Specify opposite corner of viewport:
    Enter view name: TOP
    Above is an example of the set of commands, and lines that i use on a regular basis. i dont know if this helps at all.
  6. #6
    Junior Member
    AutoCAD 2008
    Jan 2008
    14
    I use the same settings. I then get a 3rd angle layout. I'm after a 1st angle layout.
    Are you saying that you get a 1st angle layout from your settings ?
    Thanks Keith.
  7. #7
    Senior Member
    Windows 7
    Custom
    8.00 GB
    NVIDIA Quadro 2000
    INTEL SSDSC2MH120A2
    Manufacture
    Lead Detailer
    Manufacture
    AutoCAD 2012
    Oct 2007
    Hillsboro, OR
    229
    oh sorry. all you need to do for that then is to get your angle that you want, then set your UCS to the current view, then go through the same process. or if you are doing orthographic projections, use the ortho option to get your projection view.
  8. #8
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    I suspect that the other responders don't know the difference between 1st angle orthographic projection and 3rd angle orthographic projection. Maybe there is a wiki explanation somewhere that someone would like to cite.
  9. #9
    Junior Member
    AutoCAD 2008
    Jan 2008
    14
    Quote Originally Posted by JD Mather View Post
    I think you may be correct. Perhaps also I'm not explaining it too well!
    No matter where you set your UCS, when you extract a set of Ortho drawings, Autocad lays them out in 3rd angle projection.
    I wondered if there was a way of getting Autocad to use 1st angle projections.
    Keep at it ! We're all learning!
    Thanks Keith.
  10. #10
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,142
  1. setting defaults for soldraw/solview
    By WagglyFawn in forum AutoCAD Drawing Management & Output
    Last Post: 24th Oct 2006, 04:21 am
  2. Solview Problem
    By scimitar1 in forum AutoCAD Beginners' Area
    Last Post: 17th Sep 2006, 10:24 pm
  3. Replies: 5
    Last Post: 25th Jul 2005, 02:28 pm
  4. solview soldraw reverts back to pre soldraw
    By Dr.Syn in forum AutoCAD Drawing Management & Output
    Last Post: 28th Feb 2005, 09:10 pm
