Results 1 to 6 of 6
    Full Member
    AutoCAD LT 2002
    Jun 2006
    Tampa, Florida
    60
    Default Drawing curves on a road.
    I read a few threads on splines, plines and arcs, but still can't get the results I'm looking for. I'm trying to draw a road with known dimensions. How do I draw the curves? Do I use spline, pline or arc?
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Unless you need a spiral, draw 2 tangents (lines or plines) and use the fillet command for the correct radius.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,638
    How would you draw the curves if you were doing it on a drafting board instead of using CAD? Since you should have all the curve data it should be a no brainer.
    Full Member
    AutoCAD LT 2002
    Jun 2006
    Tampa, Florida
    60
    I'm trying to recreate a roadway drawing that was given to me. All I had to do was put boring symbols over the drawing. I've never used a drafting board and I'm teaching myself CAD. I'm just using this drawing with dimensions on it as an exercise to get more familiar with the tools and commands. I tried using the fillet command, and it gives me close to what I want, but it starts the tangent about 200' too soon. I'll have to move every curve that I make over to the right.
    I basically have a stretch of road that is 900' long and goes into a curve approx. 600' long with a radius of 858.75'.
  5. #5
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    Learning curve geometry would help you draw this. To get curve to start at the end of the line, offset the centerline by the radius (858.75'), use the end of the offset line to draw a circle. Trim circle to create centerline curve. Adjust length with "lengthen" command.
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,638
    I agree with CarlB about learning horizontal curve geometry.
    The curve "starts" at what is called the PC or point of curvature and ends at the PT or point of tangency. You'll need to know the delta or angle of the curve and the radius. You can compute the tangent distance, curve length and chord distance if it hasn't been supplied.
    To learn more about horizontal curves just pick up a book about surveying or "Google" the term.
  1. Drawing 3D Curves
    By ChrisM in forum AutoCAD Beginners' Area
    Last Post: 1st Dec 2009, 12:41 pm
  2. UK Road TAX Petition
    By hendie in forum Catch All
    Last Post: 13th Feb 2007, 08:13 pm
  3. drawing curves
    By sweetdrum2 in forum AutoCAD Beginners' Area
    Last Post: 24th Jul 2006, 10:37 pm
  4. Road Profile
    By Jamalama in forum AutoCAD Drawing Management & Output
    Last Post: 7th Jul 2005, 06:26 pm
  5. Drawing curves if Given the Following Info.......
    By vortec_hd in forum AutoCAD Drawing Management & Output
    Last Post: 16th Jun 2005, 10:14 pm
