Results 1 to 4 of 4
Thread: Data Extraction
    Forum Newbie
    AutoCAD 2008
    Jan 2008
    2
    Default Data Extraction
    I'm using Autocad Architecture 2008. Initially, when I used the data extraction wizard and inserted a data extraction table in the drawing, the table would automatically update changes to the counts of blocks (with attributes) in the drawing when I saved. For some reason, it is no longer performing automatic updates. I tried the command DXEVAL with a setting of 2 and then saving, but even if I select Update All, the count doesn't update. I also had no luck right clicking the count cells in the data extraction table and doing a data extraction\update data extraction. Can anyone tell me what I'm doing wrong or what setting I changed by mistake?
    Super Member CADken's Avatar
    CADken's Computer Details
    Microsoft Windows 7 Ultimate
    Toshiba Satellite A135
    Intel Pentium T2080 @ 1.73GHz, 1733 Mhz, 2 Core(s), 2 Logical Processor(s)
    Slot 1: 1GB DDR Slot 2: 1GB DDR
    Toshiba 110GB, Maxtor External HD 120GB
    Notebook Monitor + 22" NEC AccuSync LCD223wxm
    AutoCAD 2010
    Jun 2006
    East Coast - Pennsylvania
    828
    have you tried exploring "LISP" functions? sorry, i'm not an Arch guy...
    Fireman | Draftsman | Fabricator
    Running Windows 7 with AutoCAD 2010
    the Battalion East Side Pride
    Forum Newbie
    AutoCAD 2008
    Jan 2008
    2
    Haven't tried writing a LISP for this--are you suggesting this would be a better way than the data extraction?
    Forum Newbie
    AutoCAD 2009
    Oct 2008
    1
    Use block& reference menu and extract data command.Also select the current drawing for block extraction wizard
    br
    stp
  1. Attribute Extraction Program?
    By tkwon in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Jun 2012, 08:03 pm
  2. Spline data extraction using lisp
    By beproj in forum AutoCAD General
    Last Post: 24th Dec 2011, 01:11 pm
  3. Data Extraction Errors
    By TerryDay in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Dec 2007, 09:12 pm
  4. Tables from Datalinking and Data Extraction in AutoCAD 2008
    By AutoCAD Insider in forum AutoCAD RSS Feeds
    Last Post: 22nd Feb 2007, 04:50 pm
  5. Now desperate for dimension extraction help
    By kitewader in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Jun 2005, 12:50 pm
