Results 1 to 3 of 3
Thread: "mo-dyno"
    Senior Member cadmench's Avatar
    AutoCAD 2008
    Oct 2007
    103
    Default "mo-dyno"
    I know that when you first make a dynamic block, you can make it annotative. What if you forget? can you go back and make it annotative after it has already been created?
    Forum Deity NBC's Avatar
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    yes you can, just type BEDIT, select the block you wish to edit.
    once in the block editor, do not select any entities, goto Properties Palette, and there should be an option in there to make the whole block annotative. then BSAVE, and then BCLOSE.
    Note, however, that should you make a whole block annotative, then all of the entities within should be set to be non-annotative.
    Life's constantly changing - keep up or get left behind
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,127
    Thanks Blue, I have been trying to figure that one out. Good tip about not selecting anything.
  1. Why do people use a "," rather than a "." as a decimal point?
    By Tempest in forum AutoCAD Beginners' Area
    Last Post: 10th Nov 2007, 12:32 am
  2. Convert "body" to "Solid"
    By powerdog in forum AutoCAD 3D Modelling & Rendering
    Last Post: 12th Jun 2007, 04:11 pm
  3. "LINK template" icons "greyed out" -why?
    By Chrisjpritchard in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Mar 2007, 10:25 pm
  4. scaling in "architectural" & "decimal"
    By maze in forum AutoCAD Beginners' Area
    Last Post: 15th Feb 2007, 04:55 pm
  5. "Union" Meshes or "Slice" 3D Mesh
    By Peter31712 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Apr 2004, 11:11 pm
