Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
  1. #11
    Full Member watso75's Avatar
    AutoCAD 2007
    Jan 2008
    32
    Cool
    Quote Originally Posted by NBC View Post
    is it anything to do with DRAGMODE ?
    http://www.cadtutor.net/faq/questions/34/
    Dragmode is the variable which makes objects visable or invisible when moving said particular object around the screen.
  2. #12
    Super Moderator Strix's Avatar
    not applicable
    Nov 2005
    Sheffield UK
    3,081
    Quote Originally Posted by mahahaavaaha View Post
    *stuff* ... This applies to all and sunder releases of ACAD. (At least since 2000). ...
    /Petri
    If you read the OP you'll see it doesn't and it's frustrating as hell when you're doing electrical drawings
    Find your new best friend at Rain Rescue
    If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
  3. #13
    not applicable
    Nov 2005
    Sheffield UK
    3,081
    Quote Originally Posted by Alan Cullen View Post
    Strix, you could create a selection set using the lisp code (setq ss (ssget)) . Then invoke the command you want and type !ss to recover the selection set. Doesn't matter then whether any part of the selection set is visible or not, it will be acted on by the command. (I think).
    Oops, sorry, Strix, I just realised you can't use that code with LT.
    It's the LT version it isn't an issue with
  1. getting 2D(Top, Left, Front) view from 3D object
    By alijahed in forum AutoCAD General
    Last Post: 16th Oct 2007, 12:38 am
  2. No outlines while moving and copying objects
    By treoleo in forum AutoCAD Drawing Management & Output
    Last Post: 9th Aug 2007, 12:37 am
  3. Left double quotation mark
    By johnengineer in forum AutoCAD Beginners' Area
    Last Post: 9th Jul 2007, 02:05 pm
  4. LEADER JUSTIFY LEFT
    By J-LYLE in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Aug 2005, 11:31 pm
