Results 1 to 8 of 8
    Senior Member
    AutoCAD 2007
    Jan 2008
    Porto, Portugal
    322
    Default associative dimensions in x-refs
    I´m trying to dimension a x-ref but the the dimension does not accompany the changes made
    Can anybody help me out,
    thank-you
    Super Member Hedgehog's Avatar
    Hedgehog's Computer Details
    XP sp 3
    Asus NCL-DE/1U E7520
    2 x Intel Xeon 7150N
    8 x Kingston KHX6400D2K2/4G 4 GB PC2-6400
    NVidia Quadro FX 5500 1 GB Pci-X 16
    2 x Seagte Barracuda 7200.10 320 GB HDD
    ViewSonic VP2290b-2Black 22” LCD
    MEP 2009
    Aug 2007
    Any Pub, Derbyshire, UK
    896
    I think you'll have to be in the xref dwg file in order for them to be associative.
    Only the lonely only ... PhotoGallery / Music
    XP sp 3
    MEP 2009
    Aug 2007
    896
    Change that... no you don't ... however changes that occur outside of editing the xref in-place won't update the associated dims... i.e. if you edit the xref by loading it up as a dwg then go back & reload the xref it won't update the dims.
    LElkins
    This may be an obvious question, but are the dimensions set to be associative when created?
    Check DIMASSOC is set to 2.
    When you do not edit an xref in place, and reload it, type DIMREGEN. This also applies to when you open the drawing. If the xref has changed since you last did DIMREGEN, then do it again.
    Hope this makes sense.
    Cheers
  5. #5
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,074
    Also, sometimes when you pick a Snap Point, if there are multiple lines that cross then you might be snapping the dimension to the wrong entity, making the associative property for something else. You can cycle through Snap points to ensure you're making the correct connection between the dimension and the entity by using the TAB key.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  6. #6
    Senior Member
    AutoCAD 2007
    Jan 2008
    Porto, Portugal
    322
    tried out the snap points, and it doesn´t work, i´ll try the dimassoc command Leikens,
    thanks
  7. #7
    LElkins
    michael,
    DIMASSOC will just make sure that new dimensions are created associative.
    Type DIMREGEN and then the dims that were created associatively will update.
    Cheers
  8. #8
    Senior Member
    AutoCAD 2007
    Jan 2008
    Porto, Portugal
    322
    Default thanks
    thanks Leikens, it worked!
  1. Associative Dimensioning
    By guyzen2004 in forum AutoCAD General
    Last Post: 1st Oct 2007, 11:06 am
  2. Associative Hatching?
    By Rooster in forum AutoCAD Drawing Management & Output
    Last Post: 1st Jun 2007, 12:23 pm
  3. Associative dimension block entity
    By LSR in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd May 2007, 06:06 pm
  4. X Refs!
    By happyunited in forum AutoCAD Drawing Management & Output
    Last Post: 6th Oct 2006, 02:20 pm
  5. associative text??
    By GOLFBLDR in forum AutoCAD Beginners' Area
    Last Post: 12th Feb 2006, 07:05 pm
