I'm trying to have a lisp run and set the variable "shtscale" by checking against another variable "dimscale" and to output something from a list ex: FULL, or 6" = 1'-0". I keep getting an "unknown command" error.
Code:(defun dwgscale () (getvar dimscale) (setq shtscale (cond ((= dimscale 1) (princ "FULL")) ((= dimscale 2) (princ "6''= 1'-0''")) ((= dimscale 4) (princ "3''= 1'-0''")) ((= dimscale 8) (princ "1 1/2''= 1'-0''")) ((= dimscale 12) (princ "1''= 1'-0''")) ((= dimscale 16) (princ "3/4''= 1'-0''")) ((= dimscale 24) (princ "1/2''= 1'-0''")) ((= dimscale 32) (princ "3/8''= 1'-0''")) (nil (princ "None")) )) )
I made some changes - if you don't use the c: after defun you need to type (dwgscale).
Code:(defun c:dwgscale (/ dimscale output) (setq dimscale (getvar "dimscale")) (setq output (cond ((= dimscale 1) "FULL") ((= dimscale 2) "6''= 1'-0''") ((= dimscale 4) "3''= 1'-0''") ((= dimscale 8) "1 1/2''= 1'-0''") ((= dimscale 12) "1''= 1'-0''") ((= dimscale 16) "3/4''= 1'-0''") ((= dimscale 24) "1/2''= 1'-0''") ((= dimscale 32) "3/8''= 1'-0''") (t "None") ) ) (princ output) (princ) )
