Results 1 to 10 of 10
Thread: Plotter setup
    Junior Member Chudder's Avatar
    AutoCAD 2008
    Jan 2008
    Australia
    11
    Default Plotter setup
    Does anyone know how to get a Canon BJ-W3000 plotter working with ACAD 2008 and windows Vista. This is a fairly old plotter and is compatible to windows 2000/NT latest and ACAD 2000i Help!!!
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    In a nutshell, I create 3D models from the client's CAD files or design sketches, which I then use to produce high quality rendered images. Click on the link in my signature to view my portfolio. I'm always looking for work, so let me know if you need any renders. :)
    3ds Max 2011
    Feb 2006
    Southern California
    8,429
    Good luck with that.
    This is one of the problems you encounter when upgrading your OS. Sometimes older hardware is no longer compatible. Have you tried contacting Canon to find out if they have any plans to release drivers for this printer to make it work on Vista? I seriously doubt they will though. The same thing happened to me when I upgraded to XP. My Canon printer, which was less than 5 years old, wouldn't work anymore. When I contacted Canon tech support, they basically laughed at me and said I needed to buy a new printer. This is why I give Canon a big thumbs down on customer support.
    "Work Smart, Not Hard"
    Click to View My Portfolio ( Updated 05/21/2013 ) --->
    http://www.rdeweese.com/
    Full Member watso75's Avatar
    AutoCAD 2007
    Jan 2008
    32
    Default Canon
    Similar problem here too, canon were less than helpfull. I was fortunate enough to have Cad on a laptop aswell which had xp running, as far as my vista machine it was buy a new printer im afraid. Good luck though and if you find a solution let me know
    Senior Member mahahaavaaha's Avatar
    AutoCAD 2009
    Jul 2007
    Finland
    340
    Hi yall!
    If memory serves, the W3000 was an HP emulator with HPGL, HPGL/2 and RTL emulations. You could try with a generic HPGL2 driver. To test, go and download the WINLINE Vista driver from www.winline.com. I don't have a canon (except my trusty MP-C70) to test. The winline driver has to be bought and costs 200 AUS dollars but you can test it for naught.
    Cheers,
    Petri
    Life is what happens to you while you're busy making other plans.
    John Lennon (1940 - 1980)
  5. #5
    Junior Member
    AutoCAD 2006
    Jan 2008
    Lublin, Poland
    13
    You can also use PDF Creator (it's free), print everthing to *.pdf (or *.jpg/*.bmp) and then print these files using Adobe Reader.
    http://www.cadaplus.com - APlus: AutoCAD plugin for Architects, over 600 new commands!!! ... and 10000 free blocks
  6. #6
    Super Member CADken's Avatar
    CADken's Computer Details
    Microsoft Windows 7 Ultimate
    Toshiba Satellite A135
    Intel Pentium T2080 @ 1.73GHz, 1733 Mhz, 2 Core(s), 2 Logical Processor(s)
    Slot 1: 1GB DDR Slot 2: 1GB DDR
    Toshiba 110GB, Maxtor External HD 120GB
    Notebook Monitor + 22" NEC AccuSync LCD223wxm
    AutoCAD 2010
    Jun 2006
    East Coast - Pennsylvania
    828
    here's how to setup plotters/printers on a VISTA OS:
    Unless Vista has the necessary drivers, the Add Printer wizard in Vista
    insists on retrieving the driver for a network printer from the computer to
    which the printer is connected. Since you can'€™t install the Vista driver on a
    WinXP computer, that means that Vista fails to connect to the network printer.
    You need to fool Vista into thinking that the network printer is actually a
    local one, so that you can install the driver directly on your Vista computer.
    Download the Vista printer driver and install it on the Vista computer.
    You'€™ll be prompted to connect the printer to your computer. Choose the option to proceed with the installation WITHOUT connecting the printer.
    Once installed, open Printers in Control Panel, right-click on the printer
    and choose Properties. Go to the Ports Tab, click Add Port, select Local
    Port, then click New Port.
    For the Port Name enter exactly the network path and share name of your
    printer, click OK, and double-check that this new port is selected with the
    checkbox next to it. Click OK to close the printer properties.
    Fireman | Draftsman | Fabricator
    Running Windows 7 with AutoCAD 2010
    the Battalion East Side Pride
  7. #7
    AutoCAD 2009
    Jul 2007
    Finland
    340
    CADKen,
    the problem here is that there IS no Vista driver for this model!
    /Petri
  8. #8
    AutoCAD 2009
    Jul 2007
    Finland
    340
    Quote Originally Posted by Belianis View Post
    See previous message....
  9. #9
    AutoCAD 2010
    Jun 2006
    828
    Quote Originally Posted by mahahaavaaha View Post
    CADKen,
    /Petri
    sorry, missed that, my post above is just a general memo I sent out to employees here with VISTA trying to connect to our printers...
  10. #10
    AutoCAD 2008
    Jan 2008
    Australia
    11
    Thanks guys, I will try using generic driver which was going to be my next question. If not its setting up another station solely to control plotting with xp or even win 2000 on it!!
    I did try canon before starting this thread, could not even get through to talk to someone, gave up after so long on hold, good eh!!!
  1. Profile setup
    By Starkey in forum AutoCAD Drawing Management & Output
    Last Post: 20th Feb 2007, 06:54 pm
  2. Page Setup
    By nauggie in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Jan 2007, 12:05 am
  3. Page Setup
    By Tatu100 in forum AutoCAD General
    Last Post: 14th Aug 2006, 01:43 pm
  4. Dimension setup
    By corbins in forum AutoCAD Beginners' Area
    Last Post: 27th Mar 2005, 03:44 pm
  5. print setup
    By camelotimage in forum AutoCAD General
    Last Post: 25th Mar 2005, 04:29 pm
