bsimpson,
Do you still need this?
If you do, could you please explain in a bit more depth what you want. I should have a few things that could help.
Cheers
Hi,
I am in need of a lisp file that will draw a vertical line from two points on two different polylines where the vertical distance of the points along the polylines is 300.
The application for the polylines are a ground line and a grade line in road desgin.
Thanks.
bsimpson,
Cheers
Give this a try
~'J'~Code:(defun C:VLN (/ acsp adoc cnt coors1 coors2 dis en1 en2 ln num p1 p2 pl1 pl2 sortpts1 sortpts2 ss1 ss2 step tmp1 tmp2 ) (setq clr (getvar "clayer")) (setvar "clayer" "0"); change layer here (setq ccl (getvar "cecolor")) (setvar "cecolor" "1");change color here (or (vl-load-com)) (or adoc (setq adoc (vla-get-activedocument (vlax-get-acad-object) ) ) ) (or acsp (setq acsp (if (= (getvar "TILEMODE") 0) (vla-get-paperspace adoc ) (vla-get-modelspace adoc ) ) ) ) (alert (strcat "Select first the lower polyline\nthen select the upper polyline")) (if (and (setq ss1 (ssget ":S" '((0 . "LWPOLYLINE")))) (setq ss2 (ssget ":S" '((0 . "LWPOLYLINE")))) ) (progn (setq en1 (ssname ss1 0) en2 (ssname ss2 0) pl1 (vlax-ename->vla-object en1) pl2 (vlax-ename->vla-object en2) ) (setq coors1 (vl-remove-if (function not) (mapcar (function (lambda (x) (if (= 10 (car x)) (cdr x) ) ) ) (entget en1) ) ) coors2 (vl-remove-if (function not) (mapcar (function (lambda (x) (if (= 10 (car x)) (cdr x) ) ) ) (entget en2) ) ) ) (setq sortpts1 (vl-sort coors1 (function (lambda (a b) (< (car a) (car b)))) ) sortpts2 (vl-sort coors2 (function (lambda (a b) (< (car a) (car b)))) ) ) (setq dis (abs (- (caar sortpts1) (car (last sortpts1)))) ) (setq step 300. num (fix (/ dis step)) cnt 0 ) (repeat (1+ num) (setq p1 (list (+ (caar sortpts1) (* cnt step)) 0 0) p2 (mapcar '+ p1 (list 0 1 0)) p1 (trans p1 1 0) p2 (trans p2 1 0) ) (if (and (setq ln (vlax-invoke acsp 'AddLine p1 p2)) (setq tmp1 (vlax-invoke ln 'IntersectWith pl1 1) tmp2 (vlax-invoke ln 'IntersectWith pl2 1) ) ) (progn (vlax-put ln 'StartPoint tmp1) (vlax-put ln 'EndPoint tmp2) (vlax-put ln 'Layer "0") (setq cnt (1+ cnt))) ) ) ) ) (setvar "clayer" clr) (setvar "cecolor" ccl) (princ) ) (princ "\n\t\t***\tStart command with VLN\t***") (princ)
The soul is healed by being with children. - Fyodor Dostoyevsky, novelist (1821-1881)
