Results 1 to 5 of 5
    Stive
    Default Subdivision exercise
    Hi, guys. I am trying to do a simple subdivision exersice. I need to draw subdivision blocks in forms of rectangles, where each side has its own length and angle in degrees, minutes and seconds. To draw the rectangle i am using a line command, and i am entering lenght of the line and then an agle: so if the line is 140 m long and has 252 degrees 54 minutes and 20 seconds angle.
    The input is: @140<252d54'20'', but nothing happneds and autocad seems doesn't understand this command, and i can not work out whats going wrong.
    Is any one knows how it needs to be done? Thanks a lot!
    Super Moderator f700es's Avatar
    f700es's Computer Details
    Windows 7 Pro (W)/Windows 10 (H)
    Dell Optiplex 9020 (W)/ Dell Inspiron 570 (H)
    Intel (W)/AMD (H)
    Intel Core i7-4770 quad (W)/AMD Athlon 2 X4 (H)
    16 GB DDR3 (W)/ 6GB DDR3 (H)
    nVidia Geforce GTX 645 (W)/nVidia GF GT430 (H)
    256 gb SSD 0/ 1TB 1 (W)/1 TB (H)
    Seagate FreeAgent Go 320gb
    Samsung P2770HD 28" LCD and Samsung B2430 (W)/Acer 28" LCD (H)
    Facilities Mgmt
    f700es's Discipline Details
    Space Database Admin
    Facilities Mgmt
    Archibus Management, Space planning, Design
    AutoCAD 2017
    Sep 2002
    Winston-Salem, NC - USA
    5,672
    Default Re: Subdivision exercise
    Quote Originally Posted by Stive
    Check your units. Make sure you are in "Survey's Units".
    Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
    - http://f700es.deviantart.com/gallery/ -
    Senior Member Kate M's Avatar
    Structural
    Revit Structure 2013
    Sep 2003
    Washington, DC
    477
    You should be able to enter distances with any units, regardless of what your display units are set to. What do you mean by "nothing happens"? No error messages, does the command stop, does the line go in the wrong direction? What does the command line say?
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    Are you first entering a starting point before you use the relative distance/angle?
  5. #5
    Stive
    Quote Originally Posted by CarlB
    nop, i set units first in der/min/sec
    and starting point i entering by clicking with the mouse on the screen.
    Thanks
