import the other sheets into the Publish dialog box, then select all the drawings, and go back to the one layout you set for the initial plot, and select it again. This will set all the rest to the same plot settings as this one.![]()
I have about 100 drawings in which I would like to publish. I did a page setup on the first drawing and would like to use this setup for the remaining drawings. Is there a quicker way of using this page setup for all the drawings instead of having to import it in each of the drawings? I find it very time consuming and tedious.
Tannar Frampton | Facilities Engineering | Revit 2013
Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
Thanks StykFace!
