Results 1 to 5 of 5
Thread: Loft
    Forum Newbie
    AutoCAD 2007
    Jan 2008
    2
    Default Loft
    Greetings, I'm trying to use the "LOFT" command to create a surfact encompassing several map contour lines which are basically one above the other. The contour lines are 1000' elevation difference from each other and the contours are approximately 5500 ft across on an average.
    The way I first attempted to do this was to copy the contours out of this drawing and dump them into a new blank drawing. I was successful at getting a complete run only once and I'm pretty sure that the first attempt was done by scaling the contours down to a very small fraction of their original size. When I've tried to duplicate this exercise, using the same steps, my computer crashes. I've tried purging the drawing first, not purging the drawing first, not scaling the contours down or scaling down to different sizes. None of these scenerios has produced a successful run.
    I also have resorted to making several duplicate copies of the drawing before trying to use the LOFT command in case the file was being corrupted. So each new run is with an original dwg file, so to speak.
    Does anyone have any suggestions that I could try?
    Thanks
    Last edited by 270; 17th Jan 2008 at 04:15 pm. Reason: Left out that I was uing version 2007 CAD
    Forum Newbie
    AutoCAD 2007
    Jan 2008
    2
    AutoCad 2007 is the version I'm using.
    Thanks
    Senior Member mahahaavaaha's Avatar
    AutoCAD 2009
    Jul 2007
    Finland
    340
    AS it's a map, have you tried moving the graphics closer to the ORIGO? Ie. 0,0. AutoCAD has problems when coordinates are big...
    /Petri
    Life is what happens to you while you're busy making other plans.
    John Lennon (1940 - 1980)
    Super Member Mr T's Avatar
    AutoCAD 2007
    Nov 2002
    Loch Oich SCOTLAND...
    1,641
    Sounds like the machine may be struggling to compute all that info. Anyway of tilling it ?
    Nick
    http://www.flickr.com/photos/80049703@N00/ http://mtbnick.fotopic.net/
    http://s240.photobucket.com/albums/ff241/dyNick_Scots/
    http://designgraphicsshowcase.blogspot.com/
    High School Classroom - 21 AutoCAD 2007, Inventor 11, COREL Draw & Paint 11. Very Unreliable Network.
    Home - AMD 2.1GHZ - 512Ram, 64 Video,
    Laptop Inventor 7, Autocad 2004, Corel 11
  5. #5
    Administrator CADTutor's Avatar
    CADTutor's Computer Details
    Windows 7 Home Premium 64bit
    Asus P7P55D-E PRO
    Intel Core i7-860
    4GB PC3-12800 C8 Corsair Dominator
    NVIDIA Quadro FX 1800 768 MB
    Intel X25-M SSD 160GB
    Samsung Spinpoint 320GB
    BenQ FP241W 24" Wide
    Education
    CADTutor's Discipline Details
    Senior Lecturer (Digital Design), Landscape Architect & Web Designer
    Education
    AutoCAD 2014
    Aug 2002
    Hampshire, UK
    3,606
    Loft does not particularly like very complex modelling (such as the one you are describing). If there's one command that's going to crash AutoCAD, it's Loft - my students are expert at it!
    Essentially, you're using the wrong tool for the job. What you need is a terrain modeller such as Civil 3D.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    AutoCAD Tutorials | How to add images to your posts | How to register successfully | Forum FAQ
  1. Perform "Loft" or similar in acad 06?!
    By sam. in forum AutoCAD General
    Last Post: 19th Nov 2007, 06:22 pm
  2. Intersection between solids and loft solid
    By lonedevil in forum AutoCAD 3D Modelling & Rendering
    Last Post: 11th Sep 2007, 10:30 pm
  3. How can I loft this ramp?
    By CADIDAC in forum AutoCAD 3D Modelling & Rendering
    Last Post: 20th Mar 2007, 01:24 pm
  4. Issues when working with wire frame models and extrude,loft, revolve commands...
    By BenGoble in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Sep 2006, 01:19 pm
