Results 1 to 6 of 6
Thread: Error Message
    Forum Newbie
    not applicable
    Jan 2008
    2
    Default Error Message
    while trying to load a shape file, i got this error message:
    Error reading shape file
    S:\2007\SMITHSGROVE\smiths-grove-boundary\smiths-grove-boundary.shx
    anybody have any idea as to what this means? I got the shape file from a an outside source.
    Senior Member James's Avatar
    Revit 2009
    Nov 2006
    UK
    357
    do you have the file in that location on your pc or network?
    10100.co.uk ONC/HNC Building Studies :: FCAD32 :: AutoCAD 2009 :: Revit 2009 :: Architectural Technician A.C.I.A.T ::
    Senior Member mahahaavaaha's Avatar
    AutoCAD 2009
    Jul 2007
    Finland
    340
    Hi,
    you are I suspect using MAP 3D even though you don't say it. I think you are trying to load an ESRI shapefile (spatial datafile). The shapefile consists of 3 files, SHP, SHX and DBF. You should contact the sender and ask for the indexfile (SHX) which seems to be missing.
    /Petri
    Life is what happens to you while you're busy making other plans.
    John Lennon (1940 - 1980)
    Forum Newbie
    not applicable
    Jan 2008
    2
    I have the file on the network, but i don't see how that makes a difference. Please explain.
    I have a the .shx file, along with all the other files and it still comes up with the error message.
  5. #5
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    Dunno if this will help, but try creating a folder on your local hard drive "e.g. C:\Jobs\test", and place the drawing and all the files in that folder. Then open the drawing from that folder and continue on and see what happens.
  6. #6
    AutoCAD 2009
    Jul 2007
    Finland
    340
    Hi,
    but are the files in the directory that the errormessage indicates? Don't know a whole lot about ESRI files and MAP shouldn't think that the path was hardcoded in the shp-file? May be wrong. If the file isn't on S: and you don't have an S:'drive, you could fool Windows/AutoCAD to think there's one. HEre's how:
    Create a new directory/folder like C:\TEST.
    Open the Command prompt (Start - Run - CMD)
    Give this command:
    subst S: C:\TEST
    Create the pathstructure under C:\Test so that the result is:
    C:\TEST\2007\SMITHSGROVE\smiths-grove-boundary\
    Copy all the files into the new directory and try reading it by selecting it from the new
    S:\2007\SMITHSGROVE\smiths-grove-boundary\ -place.
    Hope that wasn't too unclear...
    /Petri
  1. Error message
    By ScottDrummond in forum AutoCAD Drawing Management & Output
    Last Post: 7th Aug 2007, 01:13 pm
  2. Help with Error Message
    By Almittens in forum AutoCAD Beginners' Area
    Last Post: 9th Mar 2007, 02:37 pm
  3. Error Message
    By Nitelite in forum AutoCAD Drawing Management & Output
    Last Post: 10th Sep 2006, 03:49 am
  4. Pop up Error message
    By Big Mike in forum AutoCAD Drawing Management & Output
    Last Post: 28th Feb 2006, 04:20 pm
  5. Error message
    By Mike Ravenwolf in forum AutoCAD 3D Modelling & Rendering
    Last Post: 7th Dec 2005, 06:16 pm
